993 Forum 1995-1998
Dyno results, post graphs here
Old Jan 10, 2011 | 11:50 AM
Mike J's Avatar
Mike J
Originally Posted by Ed Hughes
What on earth do you mean?
(I know, I know....it isn't a 993, but it is air-cooled! Fast forward to about 1:00)
Yup, you get it!!
Old Jan 10, 2011 | 01:53 PM
Stealth 993's Avatar
Stealth 993
Mike I love your torque curve!! It makes me want to retime my cams!
Stock 1995 C4, well it have a RS pulley & Motorsound mufflers/airbox.
I can't find the dyno chart of the C4S, but it did less then the C4 on a Mustang dyno.
Old Jan 11, 2011 | 12:08 AM
Crimson Nape Racing's Avatar
Crimson Nape Racing
here's mine. rebuilt engine by Pat Williams (to stock specs) with Steve W chip and Fabspeed bypass pipes. I don't know how much difference it makes, but my air filter was uber dirty for this dyno run.
for those that don't want to go thru all the data the max hp is 270.6 and max torque is 251.6.
File Type: pdf
Old Jan 11, 2011 | 01:15 AM
aribop's Avatar
aribop
Originally Posted by jscott82
Sounds like you have a other issues to addess first. Here is mine after getting the car back into shape. Stock motor (124k miles),200 cell cats , no mufflers, stock chip, new plugs, wires, caps, rotos, injectors cleaned, intake cleaned, all fluids changed, etc, etc, etc....
From the big dip at 5500 rpm I would check for vacuum leaks or a faulty resonance valve.
I think 240 - 250 (+10 with chip) for totally stock is pretty normal on a Dynojet. On a Mustang 210-220.
Just my 2 cents.
My car is sucking wind compared to you guys.
I replaced all the vacuum lines so should not have a leak. I will definitely check the resonance valve. I also notice that my lines are all squiggly and everyone elses are relatively straight... any thoughts??
Old Jan 11, 2011 | 02:04 PM
MarinS4's Avatar
MarinS4
Here is a VRAM motor with Protomotive style turbo kit at 7 PSI on completely stock internals.
I have since rebuilt the motor to upgrade rods to Arrow, DC21 cams and flame ring the heads. I have run the boost at 10.5 PSI and its a monster. I kept the stock CR to retain that sweet off boost throttle response. Need to recheck the dyno numbers.
File Type: jpg
Old Jan 11, 2011 | 04:45 PM
aribop's Avatar
aribop
Marin, very nice!
Old Jan 11, 2011 | 09:38 PM
Mike J's Avatar
Mike J
Yup, nice HP curve!
Old Jan 11, 2011 | 11:54 PM
MarinS4's Avatar
MarinS4
It is going to be interesting to see the dyno with the DC21 cams. I suspect they will resolve the HP falling off on the top end. After my last track day a well known 550HP 993tt seems to think I have close to 500HP based on the way I pulled him in the early part of the RPM. I also pulled away from a stage3 993tt at thunderhill down the front straight. I hit 140mph before the braking zone.
7 Porsche Models That Have Aged Like Fine Wine
Old Jan 14, 2011 | 06:20 PM
ard's Avatar
ard
Ed,
your targa makes some beautiful noises on that dyno run
http://www.youtube.com/watch?v=GtZ2AjOH358
Old Jan 14, 2011 | 07:10 PM
Ed Hughes's Avatar
Ed Hughes
Thank you!
Old Jan 27, 2011 | 07:20 AM
Cristel993's Avatar
Cristel993
Here's mine. RSFW and clutch on it's way when the current clutch gives out. Not sure if I should go for an RS tranny mount too?
Wayne Schofield of Chipwizards here in the UK did the live remap and managed to eek out an extra 19whp and 16lb/ft torque. The before numbers are with the Dansk 100 cell cat and mufflers fitted.
Old Feb 9, 2011 | 01:00 PM
markc123's Avatar
markc123
I receive Alberts distributor the other day to replace the belt. Look what I found!
The secondary is 180 degrees off. Maybe this is the cause for his low readings.
mark cohen
File Type: jpg
Old Feb 9, 2011 | 05:58 PM
aribop's Avatar
aribop
We'll see. Plan on going to the dyno again tomorrow.
Old Feb 10, 2011 | 10:28 AM
AtlJimK's Avatar
AtlJimK
Previous owner's run>
Old Feb 10, 2011 | 12:55 PM
Stealth 993
Jim, not sure what happened with the blue line, but you are running a bit on the lean side.
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
