Other than some additional cabin noise, is there any adverse affect in removing the the engine sound pad? I'm worried about any increase in heat causing damage to the rear deck speakers and vinyl.
If you have deleted this would you do so again? If not, why?
If it's just drooping at the edge, you can use a thin aluminum bar to hold it up tight. I found the 1/8" 1-1/2 flat stock at Home Despot and just used the existing fasteners to hold it in place once cut to fit and drilled for the studs.
Took mine out when I dropped my engine 2 years ago. Allows a little more flat six symphony into the cabin. I like it. Also, makes the engine bay cleaner and more spacious looking.
