993 Forum 1995-1998
Distributorless Ignition
Old Dec 12, 2010 | 05:43 PM
aribop's Avatar
aribop
Question Distributorless Ignition
Anyone here dumped the distributor and is using some sort of direct ignition system?
Interested in your story....
Old Dec 12, 2010 | 06:37 PM
trophy's Avatar
trophy
Not with the stock ECU.
That will be the next step in my project once I get the car running nicely on the after-market ECU I am putting in.
I am still figuring out if i want to go to COP or coil packs. Coil Packs are easier as they have been done dozens of times.
Old Dec 12, 2010 | 06:42 PM
AOW162435's Avatar
AOW162435
Seared
Here's an option:
Clewett
Andreas
Old Dec 12, 2010 | 06:55 PM
trophy's Avatar
trophy
Originally Posted by AOW162435
Here's an option:
Clewett
Andreas
Unfortunately that won't work with a stock ecu..
Old Dec 13, 2010 | 02:07 PM
MarinS4's Avatar
MarinS4
Doing a CDI upgrade solves the problem as well. The main problem with the current setup is lack of charge time in the higher RPMS. When using a CDI box the problem is solved. There are some appealing aspects of a COP inductive coil over CDI but not for the amount of work it takes to get there.
Old Dec 13, 2010 | 05:46 PM
C2Cab95's Avatar
C2Cab95
I was wondering the other day if there was some way to modernize the ignition system.
Old Dec 14, 2010 | 12:59 AM
Body Roll's Avatar
Body Roll
What would be the benefit of getting rid of the distributors?
Old Dec 14, 2010 | 02:42 AM
chris walrod's Avatar
chris walrod
Guru
Rennlist Small
Business Sponsor
Less moving parts and more accurate control of the ignition mainly. Also, you save some coin on those Bosch caps and rotors and Beru wires
Old Dec 14, 2010 | 11:09 AM
Nollie's Avatar
Nollie
What are you putting in that will allow switching over?
Old Dec 14, 2010 | 11:22 AM
trophy's Avatar
trophy
I am putting in a ViPEC v88 ECU, its and Australian/New Zealand produced ECU.
www.vi-pec.com
This will allow me to run any ignition system I want, I have the car running on it already (with the distributors), just doing some tidying of wiring etc, then it will be off to the dyno for final tuning.
