993 Forum 1995-1998
Tie rod pinning mod - interest for a 4th tour?
Old 04-19-2012 | 01:46 PM
  #151
NP993's Avatar
NP993
I did this last weekend. Very easy with the tie rods out of the car & using a drill press.
Old 04-19-2012 | 11:45 PM
  #152
chaoscreature's Avatar
chaoscreature
Is the tool with the ball bearing in it still holding up okay? The bearing can be replaced if it has become sloppy.
Old 04-20-2012 | 01:16 AM
  #153
nile13's Avatar
nile13
Marc, thanks for letting us know! No hurry, just post when it goes out to the next guy.
Old 05-04-2012 | 11:22 PM
  #154
Marc Shaw's Avatar
Marc Shaw
Super Duper Moderator
I'm done and will pm "sawitt" for an address to send it to next.
Marc
Old 05-10-2012 | 07:20 PM
  #155
Marc Shaw's Avatar
Marc Shaw
Ok, so our own version of Flat Stanley is winging his way back across the border to his next destination further south.
Marc
Old 05-18-2012 | 12:42 AM
  #156
sawitt's Avatar
sawitt
I received the kit from Marc today and hope to get it done this weekend.
Old 05-18-2012 | 02:23 AM
  #157
mgianzero's Avatar
mgianzero
I'd be interested in trying this mod too. Can I be put on this list if there still is one?
Marc G.
Old 05-19-2012 | 08:23 PM
  #158
sawitt's Avatar
sawitt
Originally Posted by Garth S
OK, Latest list mod ...
Gerry Kokoszka --> C2Cab95--> jimb03--> Scott Waldrup --> Marc Shaw --> sawitt --> daltvater --> Nile13/Christian J --> Sean Spicer --> JPS --> element --> randytrish --> 1978formosa-->Gunter--> vincer77
I finished the mod today. There are 3 roll pins left. According to the bag they are 5/16", 1-1/2" spring pins and seem to be available from several sources. McMaster-Carr has them for $15.68 for 25 (18-8 stainless) and they have 420 stainless and zinc-plated steel also. I'm not sure what material the pins in the kit are. Plus, I'm an electrical engineer, not a mechanical engineer so the material requirements are not within my area of expertise. I'd be happy to order some and send them to the next person, or just forward the kit on. It would seem that "daltvater" is next in line. I'll PM him for his address. This was an easy mod and I really appreciate those that got this started and allowed the rest of us to benefit from it.
Old 05-19-2012 | 09:03 PM
  #159
Garth S's Avatar
Garth S
Latest update to the circ. list
--> daltvater --> Nile13/Christian J --> Sean Spicer --> JPS --> element --> randytrish --> 1978formosa-->Gunter--> vincer77 --> mgianzero
Regards the roll pins, the quoted size is correct, and the pin material initially used was a tempered carbon steel ( ie - spring steel): both inner and outer barrels of the inner tie rod end are of mild, ductile carbon steel [ tie rods are designed to bend under stress vs fail by fracture].
Any of the stainless alloys will work as well, but are not really necessary IMHO - a heavy wall normal spring steel does the job, and is likely less expensive.
Old 05-24-2012 | 12:49 AM
  #160
sawitt's Avatar
sawitt
The tie rod pinning kit is in the mail and on the way to 'nile13'. 'daltvater' asked to be skipped when I PM'd him. I added another 25 roll pins to the kit as it was down to 3. The drill bits might be getting a little dull also. Thanks for starting this Garth S; Rennlist is a great place.
Somewhat off topic, perhaps you all will appreciate this. Last weekend when I did the mod, my 17 year old daughter wondered why I had the 993 up on jack stands and so I explained what I was doing and showed her the parts in the kit. When I told her that this was started several years ago and was being sent all over North America by some guys on this internet forum about Porsches, she was absolutely fascinated and thought it was the coolest thing she had ever heard. She talked about it for two days.
Old 05-24-2012 | 01:17 AM
  #161
Slow Guy's Avatar
Slow Guy
I talked to Vincer77 last w/e about this, he may be coming over to use my lift and we'll do this on both our cars at the same time.
Old 05-24-2012 | 01:32 AM
  #162
vincer77's Avatar
vincer77
Brotherhood of the Traveling Tool.
Old 05-24-2012 | 02:03 AM
  #163
nile13's Avatar
nile13
Better than Traveling Brotherhood of Tools.
Christian, Lev, we are next.
Old 05-24-2012 | 08:19 PM
  #164
Christian J's Avatar
Christian J
Mike, I'm free after Wednesday next week and after 7pm. Pm me for directions
Old 05-24-2012 | 11:22 PM
  #165
nile13's Avatar
nile13
Will do. Do we have any chance to get lift access?
Quick Reply: Tie rod pinning mod - interest for a 4th tour?
