993 Forum 1995-1998
Door seal
Old Nov 27, 2010 | 08:31 AM
flyingchappy's Avatar
flyingchappy
Default Door seal
Since thoroughly cleaning and replacing the door sill on the drivers side, I removed most of the glue that held the rubber door seal at the back lower corner. Now the door seal won't stay put in this spot. Is there a recommended adhesive for the rubber door seal? Wurth product?
Old Nov 27, 2010 | 09:57 AM
ble2011's Avatar
ble2011
When I was rebuilding vintage Mercedes, I know that there was an extremely strong auto adhesive that I used for the seals. This was much stronger than the usual OEM. Unfortunately, I cannot remember the manufacturer. I just wanted to mention it because there are a lot of adhesives out there and some are better than others. Hopefully, someone here will chime in. One of these better adhesives should solve your dilemma.
Old Nov 27, 2010 | 10:15 AM
mike cap's Avatar
mike cap
Pliobond is what you need to use....
File Type: jpg
Old Nov 27, 2010 | 02:55 PM
flyingchappy
Thanks for the response. Is Pliobond hard to remove if I need to change the seal?
Old Nov 28, 2010 | 09:18 PM
mike cap's Avatar
mike cap
Pliobond is pretty tough stuff. The best product to remove it is MEK. Normal thinners and solvents like
3M Adhesive remover or enamel reducer will hardly touch it. Pliobond is the best adhesive to ose in this application.
Old Nov 28, 2010 | 10:46 PM
jaa1's Avatar
jaa1
you should use what the factory uses: (or so I've heard)
http://solutions.3m.com/wps/portal/3...glHH38RPXBSNbl
Old Nov 29, 2010 | 01:59 AM
NP993's Avatar
NP993
It's the corner of a door seal, not the rear main seal. That jar of rubber cement that's been sitting in your desk drawer for five years will do just fine. If you have a lot of weatherstripping to glue down, get a tube of the 3M product (called Weatherstrip Adhesive) at your local auto parts store.
Old Nov 29, 2010 | 08:14 AM
flyingchappy
Sounds good, I thought maybe anything really strong would be too hard to remove when the door seal wears and needs replacing.
Old Nov 29, 2010 | 09:12 AM
AOW162435's Avatar
AOW162435
Seared
Pure gold.
Andreas
Old Nov 29, 2010 | 02:10 PM
NP993's Avatar
NP993
Originally Posted by AOW162435
Pure gold.
Sorry. Just keeping it real.
Old Nov 29, 2010 | 02:15 PM
Linnm's Avatar
Linnm
MEK, methyl ethyl ketone, is bad stuff--best not to mess with it.
Old Nov 29, 2010 | 06:11 PM
AOW162435's Avatar
AOW162435
Seared
Sorry. Just keeping it realz.
As only you can.
Andreas
