KILLS Bugs FAST!
The car looks great! I found a tip to get bugs off easily. I was a little skeptical at first and tried it on an older car. If you use a fabric softener sheet, they come right off. First mist the area and make sure the dirt is cleaned off so you don't have abrasives on the paint. While the car is wet (doesn't make any difference if there is soap on it) just wipe the fabric sheet on the bugs and they come right off. I haven't seen any ill effects from this technique.
