993 Forum 1995-1998
10mm spacers, stock studs?
Old Aug 28, 2010 | 10:02 AM
JZ98-993's Avatar
JZ98-993
Default 10mm spacers, stock studs?
OK - Ive searched on this topic and I know spacers are a highly debated topic. Im trying to understand the maximum spacer I can run without going extended lugs. The wheels I have do not allow for bolt on adapters and I just need a slight bump out (5-10mm). 10mm would be optimal. I have seen some folks say 7mm max, but not seen the evidence supporting it. Thanks for the info
Old Aug 28, 2010 | 10:06 AM
bart1's Avatar
bart1
Hpw much thread engagement can you get with 10mm spacers and your studs? I'd say 5-7 mm would be better - I run 5mm GT3 spacers on the rear and have steel lug nuts when I do track days.
Old Aug 28, 2010 | 10:36 AM
ilko's Avatar
ilko
Agent Orange
The evidence is a simple equation. You need at least as much thread on the nut as the diameter of the bolt. Do the math.
Old Aug 28, 2010 | 10:40 AM
windydog's Avatar
windydog
I concur, 1D at a minimum.
Old Aug 28, 2010 | 11:24 AM
911PERVY's Avatar
911PERVY
7mm Max..........dont risk it
Old Aug 28, 2010 | 11:40 AM
TheOtherEric's Avatar
TheOtherEric
If you don't believe us, then switch to steel lugs and try it. You'll find that there's not enough thread left to get the lug nut completely on it.
Like they said above, pretty simple to figure out. First, switch to steel lug nuts. Then simply measure how much thread is sticking out of the lug nut in your stock configuration. That's how thick you can go.
p.s. I would absolutely NOT run 7mm spacer on my wheels (turbo twists). No freakin' way. I have 3mm and my lug bolts are right at the edge of my lug nuts.
p.p.s. anyone who's going to run spacers should switch to steel lugnuts unless you know for sure you'll have adequate engagement for that particular wheel. Or you could use alum nuts and count the number of turns as you install them, to ensure adequate engagement.
Old Aug 28, 2010 | 12:15 PM
Steve Weiner-Rennsport Systems's Avatar
RL Technical Advisor
6mm is max for stock studs on a street car.
Old Aug 28, 2010 | 01:06 PM
Steve Nagata's Avatar
Steve Nagata
My wheel guy says at least 5 full turns before torquing it down
Old Aug 28, 2010 | 01:38 PM
Garth S's Avatar
Garth S
Wheel studs are M14x1.5 ...... divide diameter by 1.5 pitch = 9.33 turns of engagement req'd.
As most stock stud/nuts/wheels combos take max. 12 turns to final torque, then (12-9.33)1.5= 4mm 'spacer' ..... 6 is OK, no more.
5 turns of engagement is not enough for me ...
Old Aug 28, 2010 | 02:15 PM
brad@tirerack.com's Avatar
brad@tirerack.com
Former Vendor
The minimum torque on a 14 x 15.mm thread pitch is 7.5 turns. 9 is better. Less is not acceptable.
http://www.tirerack.com/wheels/tech/...jsp?techid=107
Old Aug 28, 2010 | 03:53 PM
bart1's Avatar
bart1
I think it should also be noted that different wheels probably have different thicknesses there, so you should check when adding any spacer.
Old Aug 28, 2010 | 04:21 PM
Ed Burdell's Avatar
Ed Burdell
While we're on the subject, when one uses spacers, does that require an alignment? I should know this, but I don't. Thanks.
Old Aug 28, 2010 | 05:36 PM
bart1's Avatar
bart1
No.
Old Aug 28, 2010 | 07:03 PM
Greg H.'s Avatar
Greg H.
I use 8mm spacers and steel lugs sometimes with 996TT wheels on the track and I changed to longer studs. I didn't feel comfortable seeing the stud recessed in the nut.
Greg H.
