For anyone who has fitted RS engine mounts....
Has anyone fitted RS engine mounts to their relatively stock C2/C4/C2S/C4S and not modified their engine carrier?
If haven't modified your engine carrier, have you seen any damage caused to the engine carrier or other areas?
I don't track my car and I'm not planning any major power increases, so do I really need to modify the carrier if I fit RS mounts?
Is there any evidence of non-modified engine carrier failure following the fitting of RS engine mounts?
Andy
Awesome feedback guys, thanks so much.
Tognola here in the UK, who are my Porsche specialist said they have fitted many RS engine mounts over the years with no carrier mod. Guess what? No problems. They said you only need to worry if increasing displacement to 3.8 or increasing the power considerably another way.
Seared
![](http://img.photobucket.com/albums/v452/aowalter/Porsche/POD8.jpg)
Andreas
I believe that I read somewhere that you only should think about mounts if you team up the RS mounts with an RS tranny mount, could be completely off on that though!
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
FYI on the Rennline doubler -- do yourself a favor and open-up the access hole for the coil mounting nuts as with the doubler welded into place, access to the coil mounting is rediculous.
I have RS mounts and broke my engine carrier (mainly track car), I reinforced the carrier myself (1 week prior to rennline releasing their product).
+1 on the coil bolt holes. I have the Rennline gusset installed. Totally stupid. Can't get the coil off without removing the carrier. Also, it's wayyyy more stiff. Matched with Wevo (soft) they will send unbearable noise, vibration, and resonance in and out of the cabin.
Witt the RS mounts it's perfect however.
