Big Red Questions
Thanks Bill, very compelling. It's the setup that would be the impedimenet, I think, to my (soft) setup.
Can you elaborate some on each of the "lower than RS, very stiff, and effective LSD" paramenters? Since track set up is a system, with many interrelationships, it would be good to have a concise explanation of the impact of ride height, chassis stiffness, and differential on the greater rear bias afforded by the RS rears.
Thanks Bill.
Matt
Thanks Bill.
Matt
Thanks Bill....I know of a fairly stock 993 that added the RS calipers rears to his Big Red fronts. His car was lowered, PSS9s, believe it had a good LSD. Ho hum, he really couldn't tell much difference. Viper Bob had a great deal on them once upon a time.
I agree completely, if the car is set up with all the goodies you mentioned in your post, I am certain you see much better front rotor life, assuming you are driving the snot out of the car.
I suppose if I could get a set of RS rears cheap, I'd get them. Replacing those front rotors gets pretty expensive. I'd also get the EVO uprights if a bargain set were available...that will be the day!
What I'd really like, is a nice set of slotted front rotors with aluminum hats. The ones I have seen in the past were pretty expensive, so much so that replacing front rotors more frequently becomes "acceptable".
In closing, the Porsche high performance 993 cars such as the 993 RS and the 993RS CS had them...that's all the endorsement I need. If money were no object, I'd have them on already. I'd have the EVO uprights too and some better (than my old PSS9s) coil overs.
![order](https://rennlist.com/forums/graemlins/order.gif)
Thanks Bill.
Matt
Thanks Bill.
Matt
There was a great piece in one of the Race engineering journals a few months ago about bias and how to max brake performance, bottom line you want to offload as much as you can from the fronts
In closing, the Porsche high performance 993 cars such as the 993 RS and the 993RS CS had them...that's all the endorsement I need. If money were no object, I'd have them on already. I'd have the EVO uprights too and some better (than my old PSS9s) coil overs.![order](https://rennlist.com/forums/graemlins/order.gif)
DBA has their version
Prosystems can also supply what you describe
CDOC is another that has had them at times, don't know if they are still available
Thanks for all the help guys. So, anyone have a set of rears for sale...
Also, Bill, you think these may have been modified to fit a 911 (fronts I am guessing).
this is mine w/ 993RS all around
![](https://forums.pelicanparts.com/uploads17/05_10_09_+0021278944497.jpg)
the fronts don't need to be modified, you just need a flat hat for stock 993tt rotors, the back calipers are modified (like yours) w/ a caliper adapter and the 993RS/tt rear rotors are also modified to fit the 911 parking brake
Thanks again Bill. It looks like Lindsey racing sells an adapter for the 911. So I will put these up for sale as modified rears that will fit a 911 with an adapter.
I have been searching for rear calipers for sale and not having much luck. Where did you source yours from.
I have heard several times that the RS rears are nla, don't know the truth of it.
for 993tt rears go try one of the big dealers that do oem discounts
Hennesee in Atlanta( Hennesee has gotten a lot of RS parts for me too just ask), or Sunrise in Fla or Sunset in Oregon.
The reason for asking is I think I'm gonna need some new fronts, because my caliper plates are lifting, and I can't get them out. Help. I think the RS upgrade maybe too expensive though.
I bought RS rears from Sunset in Oregon in March of this year, they said there were at least 6 sets available at that time.
The calipers were ~$850 for the 2 rears + shipping, it is a very cheap upgrade, all you need is a set of 993TT rear rotors and pads and you are off.
