Big Red Questions
I am trying to install a set of OEM 993TT rear calipers on a 993 C2 and I need the adapter to switch them from top mount to side mount - does anyone no where I can get the adapters?
For those of you that have big reds all around and track the car, how is the brake bias and what pads do you run? I was thinking Pagid blacks up front and yellows in the rear. What are others doing?
I am sure you'll get lot's of great input shortly. But I am surprised you need any adapter at all? I thought they just bolt right up.
Paging the experts!
PS - as for the pad choice, if anything you'd want more bias in the rear. In Pagid-speak, you may have your yellows and blacks mixed up...
Paging the experts!
there is no adapter used at either end, a 993tt front will bolt on to a a 993 and 993tt will bolt on the back
here is a pic of them, top left is an axial mount 993tt rear, top right is an axail mount 993RS rear, bottom is a 993RS also used 993tt radial mount front, to the left are the pads, top yellow(aalso top orange) are 993 front or 993RS/tt rear, bottom yllow are 993RS/tt front and bottom orange are 993 rear(also 930 f/r & 964 f/r)
![](http://forums.pelicanparts.com/uploads12/3_19_06_+0141199048194.jpg)
here you can see how the fronts bolt on radiallly
![](http://forums.pelicanparts.com/uploads12/3_17_07_+0041205797731.jpg)
here you can see how the rears bolt on axially
![](http://forums.pelicanparts.com/uploads17/02_26_09_+0011278114391.jpg)
Now I am really confused. I installed the fronts no problem, by the way. I bought the rears and they have part numbers as follows:
993.352.425.10
993.352.426.10
Which as best as I can tell are the 993tt rears, but they are radial mount, as Bill points out for terminology. What is really interesting is they look, with the exception of the mounting, exactly like the calipers that Bill took pictures of including the pads look identical. What really makes them stand apart from the fronts is the brake line connection point - which is centered for the rears. So, any ideas of what I might have?
993.352.425.10
993.352.426.10
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Could you post an image of these rears? Those part numbers appear correct so something is really off here.
I am helping Certz install the brakes on the car. The issue he states is 100% correct. Below is a pic of the actual calipers which have part #'s 993.352.425.10 & 993.352.426.10 on them. Also the piston sizes on this set are smaller & all the same size where as the fronts have 2 larger pistons and 2 smaller ones so they dont seem to be front calipers. When you check the part # they state they are 95-98 Turbo Calipers. It seems like we need an axial mount to radial mount adapter.
![Smile](https://rennlist.com/forums/images/icons/icon7.gif)
I have 993 TT front and rear calipers on my 97 Carrera. Yes the RS would b e nice, bigger pistons...but the standard Big Reds do just fine. I use Pagid Blacks on the rear to generate a little more bite on the rear.
My car is a track car....6 to 8 events a year. I have had plenty of hard braking experience with the car. The Turbo Big Reds have never let me down.
Get the RS rear calipers for bragging rights, but will they rock your world? I doubt it. And besides, nobody ever went fast standing on the brakes.
Racetechnology used to modify them for use on a 911 by machining the axial ears off and drilling for radial mount, from left here unmodified 993tt rears, modified 993RS rears(993tt & 993RS use the same rear caliper just w/ different piston setups), 993RS/tt front
![](http://forums.pelicanparts.com/uploads17/renntechbr+0271268142237.jpg)
no one ever made a set of caliper adapters for those, no need.
my best advice is to sell those and get a set of unmolested 993RS or tt rears
the#1 edge is that brake loads are off loaded from the overworked fronts, result quicker stops and lower front rotor temps at the cost of higher rear rotor temps, front rotor life will be almost doubled.
I've been monitoring rotor temps at track days and am amazed at some of the findings, so far just on 993, 996 & 997 the guys i run w/ most and have lined up a Cayman S and stock class SC racer car for future monitoring
generalization the fronts of all the stock911/996/997 cars run hotter than he** and the rears are tepid, on mine w/ RS brakes front and rear temps are comparable and way cooler than the other fronts / hotter than the other rears
Bill, that's excellent research, thanks for sharing. Can you provide some examples of the temps you've observed on the TT/RS setup front and rear vs. stock?
We've each commented in the past on the merits of the BR upgrade. What appeals to me most are the lower temps in general, and with the greater rear bias on the RS rears, dramatically lower (balanced, with respect to the rear) front temps and wear.
Thanks again.
Best,
Matt
Thanks again.
Best,
Matt
Thanks again.
Best,
Matt
Thanks again.
Best,
Matt
More data coming
just a note: to run the RS rears you need a lowered car(lower than RS), stiff suspension(RS or better) and effective lsd(motorsports or GT)
