993 Forum 1995-1998
A/C diagnosis
Old 07-11-2010 | 07:35 PM
JM993's Avatar
JM993
Hey Emerald,
At this point it makes sense to change everything while the system is open and the car apart. Frankly, I would have suggested renewing the expansion valve and dryer anyway on a car of this age.
Take lots of pictures for us and good luck!
Joe
Old 07-11-2010 | 07:52 PM
e3photo's Avatar
e3photo
Hey Joe,
Yeah, I agree with you. I figure if I have to take it all apart, I am going with new evaporator,expansion valve, and drier. Debating about compressor.
Emerald
Old 07-11-2010 | 08:11 PM
e3photo's Avatar
e3photo
The Griffiths is about $200 more. Is it worth it, and would you consider replacing the hose in the engine compartment?
Thanks,
Emerald
Old 07-12-2010 | 12:17 AM
JM993's Avatar
JM993
Originally Posted by e3photo
Hey Joe,
Emerald
I'd leave the compressor. They tend to be robust and are easy to change at a later time. As for the hoses in the engine bay, you'll be appalled at how much those cost new. I'd wait for those to go bad and then have new rubber fit to the factory connectors.
Cheers,
Joe
Old 07-12-2010 | 01:53 AM
e3photo's Avatar
e3photo
Thanks Joe.
I guess I should just wait till the compressor goes bad.
I never thought about having the hoses replaced on the original metal. I guess when the time comes, I could just send it out to Amazon Hose in Florida. I guess they could do it, I know they do fuel lines.
Thanks again,
Emerald
Old 07-12-2010 | 08:43 AM
Toga's Avatar
Toga
Emerald, while you there, I would suggest you remove the left side under body panel (sill cover). This is where the 2 tubes run from the engine compartment to the front of the car. You'll see that there is a bolted connection in front of the rear left wheel. Check that connection too, mine was leaking there!
Old 07-12-2010 | 11:05 AM
e3photo's Avatar
e3photo
Thanks JP,
I'll check there as well.
Emerald
Old 07-14-2010 | 09:39 PM
Rick Lee's Avatar
Rick Lee
Subscribing. Mine just started acting up today. 14 yrs. of never having been serviced and on my third summer in AZ. I guess this a/c doesn't own me too much more. How much are you looking at for all your parts?
Old 07-14-2010 | 11:48 PM
e3photo's Avatar
e3photo
Hey Rick,
I am expecting my parts to arrive tomorrow. I went with Griffiths Kuel evaporator, which comes with the expansion valve already on it, and a new drier. It ran $631 with shipping.
I have a couple of things to do to clear some time before diving in.
I think I am going to find a set of hoses for the engine compartment from a 96-98 while I am at it as I am building a varioram engine for the car.
Any one got the lines from an a/c delete?
Emerald
Quick Reply: A/C diagnosis
