Finished With DIY Suspension install, THANKS "InTheAir"!!
This Thread has been Edited a few times and the most recent post is #11, So you dont waste your time.
The HD rear drop links are ~ 25mm shorter than stock links ..... without the correct links, there is a good chance of having the bar interfere with the rear arm of the LCR ( 'A' arm).
The only way to avoid that is to raise the suspension height to SUV levels - which generally defeats one of the objectives of doing the suspension upgrade.
Now I need help with the rear spring perch, cant tell from the pics how it is supposed to be. Loose or right in between the spring and shock, Cause I cant get it to fit in between.
Make sure you get the lock ring to drop link mount really tight. Once I got mine shock on the car I used a screw driver in one of the notches and a rubber mallet to make sure it was locked down. After on the car to make sure the drop link mount was in the right position.
One more thing, I saw your note about the springs not touching when there is no load. I noticed this more on the rear. You can tie the top of the spring to the top cap with a piece of wire and running it up through the rubber piece that comes down the spring. You need to do this before you mount the shock.
-Doug
Everything is done thank God with no major complications.
I didnt tie the spring in place and I will hope it will just pop into place when the car is dropped. i heard it pop this time so im good untill the next time I lift the car. lol.
Thats a pretty dumb thing I cant believe they didnt work out a solution for that.
I just got your vm. Glad to hear everything worked out.
Enjoy!
Joe
