993 Forum 1995-1998
Tail panels and brake lights not fitting together snug
Old 06-01-2010 | 01:25 AM
Moto61's Avatar
Moto61
5th Gear
Default Tail panels and brake lights not fitting together snug
I had the tail lights and center panel off today to dry out some condensation in the reverse light lens. When I re-intalled everything I realized that there is too large of a gap between the side indicator lights and the center reflector/brake light. In fact, the 3 prongs on the end of the side indicator lights don't even reach into the holes on the end of center piece.
What's up with this? I know they didn't shrink...
All suggestions appreciated.
Old 06-01-2010 | 01:52 AM
sanyata's Avatar
sanyata
Did you look in your manual under replacing the rear bulbs? There is a good description of the center piece adjustment screws that are on the top of the rear panel. It sounds like you didn't loosen them up when you took the panel out so now they are not letting you slide the piece back end completely. Don't ask me how I know....
Old 06-01-2010 | 02:06 AM
Moto61's Avatar
Moto61
5th Gear
In fact, I did check that and the center piece is in tight, flat and correct. It's almost as if either the center panel or the side lights are too short by 1/4 of an inch.
Old 06-01-2010 | 02:55 AM
Marc Shaw's Avatar
Marc Shaw
Super Duper Moderator
There are supposed to be little rubber flaps attached to the centre piece that fill the gap between the centre piece and the side lights.
Marc
Old 06-01-2010 | 03:09 AM
Moto61's Avatar
Moto61
5th Gear
I don't see that rubber piece in the parts catalogue or other sources. How do I replace this without buying a whole new center piece?
Also, this would fill the gap visually, but I would not solve the problem of the 3 prongs on the side light fitting into the side of the center panel.
Old 06-01-2010 | 05:43 AM
911PERVY's Avatar
911PERVY
Not sure about the rubber flaps bit, there is a rubber edge behind the plastic leading edge, I guess yo mean this but I doubt if this is lost or would cure your problem.
Try locating the corner lights into the reflector 1st (3 prongs in) then locate the screw on the light in the hole and you should be able to move the light unit a little before screwing it up fully
Old 06-01-2010 | 03:12 PM
Moto61's Avatar
Moto61
5th Gear
Yes I did that, but to get the screw in hte hole for the side light, the piece has to move over and then the 3 prongs move out of the holes.
Old 06-01-2010 | 03:23 PM
Marc Shaw's Avatar
Marc Shaw
They are an integral part of the centre panel.
Marc
Old 06-01-2010 | 03:57 PM
Moto61's Avatar
Moto61
5th Gear
I would expect that means the replacement of the entire center piece which is very expensive.
