Wanna see what a 15 years old non-update engine harness look like?
Consider yourself a lucky one. Anyone who searches will see posts and pics from 8-9 years ago when EJ was pushing to get Porsche to acknowledge the problem and issue a recall/TSB. There were some scary pics...and the harness from my MY93 was also in pretty bad shape and the car was shorting/running rough, especially in heavy rains.
![](http://forums.pelicanparts.com/uploads17/100_00451274509281.jpg)
I purchased my 1st porsche 2 weeks ago. It is a 1996 993 with 32,000 miles. I purchased it from a local colleague (doctor). he was the 3rd owner and bought it in 2002. Do you know if the 1996 had harness problems also? I guess I should ask him if he knows if this had been changed. thanks in advance. BTW, I LUV MY NEW CAR/MISTRESS :-)
Rodney
Rodney
I also did not mean to imply that the 928s had a wiring harness problem. Generally fires happen in cars more often then the manufacturers let on, only if it gets seriously bad do they issue a recall or announcement. The 993 wire harness was a know issue among Porsche mechanics for many years, and it took the effort of rennlister EJ and others for Porsche to finally admit the issue. Other Porsches have had issues with gas lines and power steering fluid, and there have been a few posts reporting electrical shorts and fires. Also don't forget the possibility of aftermarket electronics shorting out.
The Lucas motto: "Get home before dark."
Lucas - Inventor of the self-dimming headlamp
The Original Anti-Theft Device - Lucas Electrics
Lucas is an acronym for Loose Unsoldered Connections and Splices
Lucas systems actually uses AC current; it just has a random frequency.
If Lucas made guns, wars would not start
Back in the 70's, Lucas decided to diversify its product line and began manufacturing vacuum cleaners. It was the only product they offered which did not suck.
Copied from another site:
Description
Have you inadvertantly let the smoke out of the wires on your classic British car? This, then, is the solution to your problem!
Here is presented for your perusal one Lucas Replacement Wiring Harness Smoke kit, P/N 530433, along with the very rare Churchill Tool 18G548BS adapter tube and metering valve. These kits were supplied surreptitiously to Lucas factory technicians as a trouble-shooting and repair aid for the rectification of chronic electrical problems on a plethora of British cars. The smoke is metered, through the fuse box, into the circuit which has released it's original smoke until the leak is located and repaired. The affected circuit is then rectified and the replacement smoke re-introduced. An advantage over the cheap repro smoke kits currently available is the exceptionally rare Churchill metering valve and fuse box adapter. It enables the intrepid and highly skilled British Car Technician to meter the precise amount of genuine Lucas smoke required by the circuit.
Unlike the cheap, far-eastern replacement DIYsmoke offered by the "usual suppliers", this kit includes a filter to ensure that all the smoke is of consistent size, It has been our experience in our shop that the reproduction Tiawanese smoke is often "lumpy", which will cause excessive resistance in our finely-engineered British harnesses and components. This is often the cause of failure in the repro electrical parts currently available, causing much consternation and misplaced cursing of the big three suppliers.
These kits have long been the secret weapon of the "Ultimate Authorities" in the trade, and this may be the last one available. Be forewarned, though, that it is not applicable to any British vehicle built after the discontinuing of bullet connectors, so you Range Rover types are still on your own...
This Genuine Factory Authorised kit contains enough smoke to recharge the entire window circuit on a 420 Jaguar, and my dear friend and advisor George Wolf of British Auto Specialty assures me that he can replace ALL the smoke in a W&F Barrett All-Weather Invalid Car(147 CC) with enough left over to test a whole box of Wind-Tone horns for escaped smoke. How much more of an endorsement do you need?
More, you say? Well, I once let the smoke out of the overdrive wiring on my friend Roger Hankey's TR3B, and was able to drive over 200 miles home from The Roadster Factory Summer Party by carefully introducing smoke into the failed circuit WITHOUT even properly repairing the leak. Another friend, Richard Stephenson, was able to repair the cooling fan circuit of his Series 1 E-type by merely replacing a fuse and injecting a small quantity of smoke back into the wires. So there!
So, if you're troubled by lost smoke, bid early and bid often! Thanks for looking!
Description
