993 Forum 1995-1998
Paint under stone guard
Old 05-24-2010, 11:55 PM
KMASS993
KMASS993's Avatar
Default Paint under stone guard
So this past weekend I began removing my cracked stone guards... of course to reveal that the paint underneath had taken a similar look. I don't know if they have never been changed, but the paint underneath the stone guards actually has a permanent "cracked" look to it, and which you can feel with a finger nail. Now I am afraid that w/ new stone guards, you will still be able to see this... any ideas on how this would be removed? I am guessing some wet sanding? Any ideas would be appreciated.
Regards,
Kevin
P.s. has anyone ever seen black stone guards for the 993?
Old 05-25-2010, 07:26 AM
SKM
SKM's Avatar
Default Stone guards
What color is your 993? A few of the factory stone guards for 993s were painted body color underneath. Not sure how this done, but perhaps these can be ordered or made for yours.
Old 05-29-2010, 12:56 AM
KMASS993
KMASS993's Avatar
My car is black. I tried looking for black stone guards, but it appears that they only come for a 930, which look a little thinner. The strangest part about this whole thing is that the paint under the passenger side stone guard is completely smooth. I just don't understand how the paint could even get like it is now, I mean the cracks in the stone guard are so small, very strange. Maybe the car was always parked in the sun in that direction at the po's residence? I am wondering if a body shop would be able to wet sand it down to be even or if a detailer could do paint correction on it.
Old 05-29-2010, 09:30 AM
95_993
95_993's Avatar
Sounds like it is worth taking to a detailer like RickRack (no affiliation - just seems highly recommended in the Bos area) to take a closer look.
As for the black stone guards, I would swear that a black 993 c4s I passed on I-95 a week ago had matte black stone guards on it.
Old 05-29-2010, 12:30 PM
KMASS993
KMASS993's Avatar
I called Rick at Unique Car Care... we will see what he can do (for that spot and the rest of my car)... I have only seen 930 stone guards in black, I wonder how they stack up in size against the 993 ones.
Old 05-29-2010, 12:41 PM
MarkD
MarkD's Avatar
They are pretty different in size and shape.
Good luck with the paint repair! That is really odd..
If you get a chance maybe you could post a pic or 2? I am just curious.
Old 05-29-2010, 02:21 PM
KMASS993
KMASS993's Avatar
Here is a pic, you can see in the reflection the lines that I am talking about. You can feel these when rubbing your hands across the paint. Looks like alligator skin!
Old 05-29-2010, 06:34 PM
Akerlie
Akerlie's Avatar
are you sure that isn't remains of the stone guard glue ? Try some citrus cleaner on it and check what happens. When i changed mine the glue was a PITA to remove and the paint underneath was good as new.
Old 05-29-2010, 06:57 PM
KMASS993
KMASS993's Avatar
There is no glue left on the panel... the lines you see are actual depressions in the paint that are noticeable when you run your fingers over the panel. It is just the strangest thing ever, def wasn't expecting this when I took them off. What is even more strange as I said above, the other side doesn't appear to have this.
Old 05-29-2010, 08:05 PM
MarkD
MarkD's Avatar
was that side repainted?
If so, I'd guess the guard was applied before the clear was cured.
Just a guess... from a non-professional, arm-chair paint guy
Old 05-29-2010, 08:44 PM
NC TRACKRAT
NC TRACKRAT's Avatar
It would appear to me that the paint took on the mirror image of the degraded stone guard. If you have non-clear coated paint, wet-sanding may well be the potential solution. If it's a clear coat, then you can only go so deep w/o going through the clear coat into the base coat. Try some rubbing compound on a rag. If it turns black, you don't have clear coat.
Old 05-29-2010, 09:17 PM
KMASS993
KMASS993's Avatar
I am having the whole car looked at by a detailer and will get input on what happened and how it can be fixed. Worst case scenario I will get a black stone guard (made if I can't find one) and cover it up until I plan on painting the car.
Old 05-29-2010, 09:23 PM
95_993
95_993's Avatar
Of you find the material that the black 930 stone guards are, you can then cut a pair for yourself.
Quick Reply: Paint under stone guard
