dual distributor exploded view
I thought I had an exploded view of the twin distributor in my mind, up until a call this weekend from a friend, with a simple question, and I am getting old.
if you dismantle the whole thing, piece by piece. you will find 4 white washers, 2 smaller than the other two. they install one big one small.
the first duo install below bottom bearing on secondary shaft, bottom bearing - silver washer - smaller silver washer - circlip - grease - protective cover.
Where do the other duo go ? is it above hall sensor mechanism, below ?
surely not below main shaft lower bearing, there are two black washers IIRC, also one small one big, but bigger than those mentioned above. thanks
M. Schneider (07-23-2023)
Great pic.
Ken
Ken
Thank you very much Jason, once more
