Cost of suspension install with Alignment?
Just woundering what I can expect to pay to get my suspension installed and car aligned?
Will it make a diffrence if I add a rear sway bar?
6-8 hours shop time for the suspension installation
$100 - $120 for an alignment, more if you go for a corner balance...$300 ish
The rear sway is a piece of cake, probably 0.5 hours shop time.
No front sway?
Make sure your wrench and alignment shops know how to work on a 993. I have found that this excludes most P-dealers. They have folks who work on the new cars, not so much on our vintage ride.
Bob-
No front sway?
Bob-
Rothsport did mine. they know their stuff, be sure to discuss just where you want the ride height to be. they recommended no change of sways unless I was planning to track the car
And don't forget to factor for unintended consequences. My car went for an alignment + c/b using the existing suspension, plus installation of a set of Walrod bushings. The shop found my rear toe-links were shot and after all was said and done the bill was $2K (~$1200 for labor.)
+1
Thanks for all your replies guys!
It's a really easy job. You might want to save some $$$ and do it yourself
FWIW - I paid $420 for an alignment and corner balance just the other day.
Cheers,
Joe
Since putting my Walrod bushings I'm looking to get mine aligned and corner balanced, mind if I ask where you went. I've not found a good alignment shop in the Sacramento area.
