993 Forum 1995-1998
A/C clutch won't disengage
Old 05-18-2010, 01:18 AM
Greg H.
Greg H.'s Avatar
Default A/C clutch won't disengage
I read all the archived A/C threads and it seems most people have the opposite problem. My clutch is always engaged no matter what buttons are pushed, key on or off. The a/c appears to be going all the time, but the climate control seems to work properly. I had the heat on today and everything was great.
I hope it's the A/C relay, but was wondering if it might be a CCU failure or something else. Anyone seen this problem?
Greg H.
Old 05-18-2010, 10:30 AM
Garth S
Garth S's Avatar
Disconnect the single wire from the AC compressor - a female spade connector on ~10" of wire: if the clutch does not disengage, the clutch is dead .... if it does, then there is +12V at the male spade ( which you can verify with a meter) ... which indicates a CCU issue: I believe the AC relay is integral to the CCU, as in the 928's, as I do no recall a separate relay in the CE panel.
Aha, the AC relay is in the engine bay panel, left side and in slot #3 .... easy to swap out with another similar relay for a test.
Last edited by Garth S; 05-19-2010 at 12:15 PM. Reason: not so instant recall ... of relay location
Old 05-18-2010, 10:46 AM
ToreB
ToreB's Avatar
Never seen that one before, you may have a faulty relay yes. Or maybe a stuck magnet clutch?
Pull the relay and test if there's any +12V on terminal 2 (pin 85 on the relay) That's the control input from the CCU. This signal goes through the 3-level pressure switch in the luggage compartment to disengage if there's any problem with pressure.
If the clutch disengage when pulling the relay you at least have a good clutch.
Do you get any warm air at all? If not you may have a problem with the CCU itself. But, don't despair, almost all of the internals in that can be fixed.
You could also pull out the CCU and test if there's any +12V on the K24 terminal/pin, both harnesses still connected to the car of course. If so, you may have a problem with the circuitry inside.
Regards,
Tore
Old 05-18-2010, 01:09 PM
Greg H.
Greg H.'s Avatar
Thanks for the tips, guys. I guess I should have been clearer: My clutch is engaged when the battery is hooked up, but disengages when the battery is disconnected. I do get heat and cold on demand. I assume the cooling system is running all the time because I just realized I get a huge puddle of water (condensate?) under the car after driving it - even when not using the a/c. I will check the relay first.
Greg H.
Old 01-21-2017, 05:25 PM
Humf
2nd Gear
Humf's Avatar
I have the same problem, ac clutch is constantly engaged, pulling the relay turns it off, but otherwise it is clicked on. The switch on the CCU has no effect. Any help appreciated.
Old 06-09-2017, 09:43 AM
ALLPRO
ALLPRO's Avatar
same problem of 964
green relay (in engine box) ac compressor is always excited
+12 constant
is "CCU" the problem?
very thanks
Old 06-09-2017, 12:19 PM
Opo
Opo's Avatar
More likely low on freon imo
Old 06-10-2017, 02:04 PM
csmab
csmab's Avatar
Low on freon. Mine did the same thing. Had it charged and it fixed the problem. Compressor would cycle on and off as expected after full charge. Even though the system was very low on freon it was still blowing cold.
Old 06-10-2017, 03:05 PM
nine9six
nine9six's Avatar
Rudy, Rudy, Rudy! ; )
Old 06-11-2017, 03:54 AM
Opo
Opo's Avatar
Old 06-11-2017, 04:39 AM
ToreB
ToreB's Avatar
Low cooling media level does not cause the A/C clutch to engage, but the opposite. The three-level pressure switch will turn off the A/C clutch signal if the pressure is too low.
I guess this is a failed clutch relay. The fault finding procedure is mentioned above in Post #3.
I would recommend to remove the clutch fuse until this issue is resolved, the compressor can be damaged if it runs with low cooling media level. This also puts a uneccessary strain on the belt on engine startup.
Cheers,
Tore
Old 06-19-2017, 06:05 AM
ALLPRO
ALLPRO's Avatar
Lightbulb
Hello Toreb, I'm your Italian friend
I'm just working on this issue and almost solved ...
As we talked about in days past, of the various contacts of the pressure switch between 964 and 993
In my case was mounted a non-original pressure switch, then unsuccessful, cut the wires to add, another anti-bridging control, and mixed the wires ...
I removed the additional probe, and reset the order of the wires ... now the compressor only pauses with the button pressed ... so it works perfectly.
There is only one problem, almost immediately the fast fan, (ok new and working resistance), most likely, the competition switch is a bit damaged or too much pressure on the plant to be tested.
Soon new updates ....
Old 06-19-2017, 06:15 AM
ToreB
ToreB's Avatar
Great news, thanks for the update.
Cheers,
Old 06-19-2017, 04:52 PM
pp000830
pp000830's Avatar
Received 1,519 Likes on 1,074 Posts
Doesn't the compressor run even with the heat on when defrosting?
Old 06-20-2017, 03:17 AM
ToreB
ToreB's Avatar
The A/C compressor engages when pressing the A/C buttons or Defrost. The evaporator will dehumidify fresh or recycled air.
Cheers,
Tore
Quick Reply: A/C clutch won't disengage
