RS/Evo Uprights, Tie Rods and Bushing replacement with Updates
#76
This is a nice drawing of anti-squat geometries:
![](http://gregwealch.com/images/anti-squat.gif)
#78
The best explanation I found is here at Race Car Tuning
If the convergence is at ground level that is 0% anti-squat where only the rear springs resist squat.
If the convergence point is above the CG level then there is front end lifting - which is what drag racers want because front wheels off ground = all weight on rear wheels.
If the convergence point is below ground level then there would be front end weight transfer driven by rear wheel torque.
#79
Also interesting to not is the relation ship between the tilt kit and adjusting the KT arm.
when the KT arm is lengthened both caster and camber decrease, rear caster spec for RSR was 3° or as close to tilting the forward part of the rear suspension down as it gets.
