Rear-ended, hit and run
#31
Total bummer -- but really, you don't need a quarter panel. That would be a massive over-reaction probably driven by the body shop guy having dollar signs in his eyes.
The end of the panel got bent down a little bit. A metal guy will be able to straighten it out in 45 minutes with no bondo. Once you take the bumper off and remove the tail light, there is total access on the underside. Don't let a body shop talk you into replacing the panel -- that involves extensive cutting, welding, etc. Welds are a rust magnet. Your car looks ugly right now, but really, this is a very minor fender-bender.
A good shop can repair without the quarter panel being replaced. Less invasive = better if possible and this is very doable as Noah stated.
The spoiler replacement depends on where the damage is. If the mount points are messed up then it might need to be replaced.
I think you know this but I'll state the obvious: Take your time with the body shop and make it clear the kind of repair you expect. I would ask to stop by and check progress before paint...
#33
It's very noticeable when the gaps are not equal on both sides. Make sure the tailgate lines up perfectly both ends. Expect nothing but the best results.
#34
Quadcammer -
Sorry for your troubles, sounds very frustrating. In regards to body shops, give Dave Jenkins @ DJ's Auto Body in Morristown a call, he does alot of Porsches. He just repaired/re-sprayed my rear bumper and sprayed my new front euro turbo bumper. His work is good. His # is: 973-538-7207
#35
Don't change the quarter panel if you can avoid it. Maybe better to repair it as to leave the original spot welding intact.
On looking at the damage to his vehicle, there maybe a small chance he did not notice that he a had damaged your car. Surely he would have at least wiped away your red rear lens from his vehicle to hide the evidence if he was that dishonest, and then parked somewhere else.
But to not acknowledge it once the vehicles were lined up and the damage examined is WEAK.
#36
Quadcammer -
I've heard that as well. I'd like Paterek but since they are so busy and I've heard won't work on anything but 356s, DJs is definitely a good choice.
I hate dealing with body shops, but I don't have a choice.
This WILL be repaired correctly.
#37
If you are willing to go to Central NJ, Bodymotion has a great reputation with body repairs (located in Ocean, NJ). Also, recently had work done at Lee's Garage in West Long Branch. Excellent quality and local dealer Schneider Nelson Porsche sends him lots of work.
Mark
Mark
#38
That just sucks.
If you were closer you would be more than welcome to my old POS dented DD for a couple of ramming sessions on his junker.
Oh well, it can be fixed and will come out better than ever. Keep your chin up knowing that an entire rennlist army is heaving bad juju his way.
#41
#43
I'm sorry to hear about this. Can't believe the guy would deny hitting you. How embarrassing for the a$$hole, with all the evidence on your side. It would so much easier on both of you if he'd just act like a man and not a weasel.
Sorry this happened. A good body shop will take care of you.
chuck
chuck
#44
chuck
chuck
as for taking him for a "trip" to the swamp, my italian gf already offered, but I'll be the bigger man.
#45
precisely. He's just making life hard by denying this. I wouldn't have said a word about hit and run had he just admitted it. Now there is a possibility of criminal charges. so stupid.
