mounting V1 near rear window
I'm thinking of moving my V1 from above the rearview mirror to the rear of the car by the rear glass....either on the ceiling below the third brake light or on the rear package shelf. I'd like to hide it in some kind of housing so that it's not so obvious and visible. Has anyone done this? If so could you post a pic of the housing you used?
TIA
TIA
Somewhat OT to your question, but I got threatened with a ticket from a CHP for having a V1 due to this CA law: http://www.dmv.ca.gov/pubs/vctop/d12/vc26708.htm
He didn't end up giving me a ticket; instead he gave me a fix-it ticket for no front plate........
This is where I mounted my V1. Can't tell unless you really look.
https://rennlist.com/forums/993-foru...pinions-4.html
I used a 964 brake light housing. Cut a hole for the V1 and converted the tail light bulb to a flat LED element.
![](http://i454.photobucket.com/albums/qq264/DavidinHK/Valentine%20One%20mount/IMG_9971.jpg)
![](http://i454.photobucket.com/albums/qq264/DavidinHK/Valentine%20One%20mount/IMG_0736.jpg)
Post is here:
https://rennlist.com/forums/showthre...eferrerid=9491
The V1 mount is attached to an aluminum plate that is held on by the visor retaining clips....no holes drilled and completely reversible. I have a remote display (modified with red/yellow/green/blue LEDs for different alerts) so the V1 main unit is completely dark and a remote mute button on the turn signal stalk so much easier to access than reaching for the remote display or main unit to mute.
![](http://i454.photobucket.com/albums/qq264/DavidinHK/Valentine%20One%20mount/IMG_0734.jpg)
[QUOTE=David in LA;7490662]Thanks...I actually responded to your post in that thread asking for details of your install. Any chance you have the part number for the 964 housing? Did you have to drill holes to mount it or are there holes already under the headliner? TIA!
I looked it up in PET and the part numbers are 911 631 070 00 and 911 631 061 01. However, the 928 part looked almost the same. You can see it here in one on ebay.
http://cgi.ebay.com/ebaymotors/Porsc...Q5fAccessories
It is attached to the window by doublestick tape. So it is completely reversible.
Found the 964 one. Not sure what's the diff between 928 and 964, but I used the 964.
Open the unit up with the screw, discard innards, cut hole in housing for V1, attach V1 using double stick or velcro, use led bulb or panel to replace brake bulb, put back together, double stick it to your rear windshield.
