993 Forum 1995-1998
LATEST UPGRADES WITH PICS!!!
Old Apr 3, 2010 | 05:44 PM
993C4RS's Avatar
993C4RS
Default LATEST UPGRADES WITH PICS!!!
Hello Everyone!
As the title states... enjoy!
Front bumper respray... ( bad stone chips)
Existing clear corners "smoked"... done by same paint shop...
Hella Micro DE installed... I installed these actually onto the front bumper in the
foglight recess. After some modifying, I was able to make the T/S duct fit
over the foglight without being attached to it. ( does that make sense?)
I also like how the Hella's have little vertical lines in the lenses, they look
like the same lines in our headlights...
While I had the front bumper off I decided to "swiss cheese" my bumper
support. Whatever, I was bored... shaved less than 2 lbs.
Odyssey 925 battery... My battery finally died for good after about 4 yrs.
so I figured time to upgrade! I decided on the Odyssey 925 over the 680
for streetability. I liked the Rennline bracket, but to save $ I made a simpler
bracket and used the factory location. ..shaved 10 lbs.
Rennline lower dash and radio block off plate... Fit and finish is awesome,
I got the black finish which is almost an exact match to the plastic bits
like the steering column cover, center console plastics, etc.
My 1st plan was to have the items wrapped in leatherette as soon as
I received them, but I think I'll hold off for now... shaved about 20 lbs.
Seine Systems carbon hood props front and rear... cool products, but I just
didn't like the way they want you to install them. So I made a mount for
the rear prop, off one of my existing bolts that connect my carbon wing
to the carbon decklid... the tip of the prop goes into a stainless allen bolt
that replaces one of the motor mount bolts... ( front prop not installed yet )
Just finished a corner bal. and align... dropped the front about 1/2" more
and the rear 1/4" more...
Total weight w/ half tank, about 2950!!
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old Apr 3, 2010 | 07:07 PM
ABCar's Avatar
ABCar
So very nice! Love the battery and bumper...and the hood prop and foglights...and the radio delete...Hell, it's all good! Very professional grade work too. How did your body shop smoke the lights?
Old Apr 3, 2010 | 07:11 PM
jhale's Avatar
jhale
Looks great. Curious how you rigged the Hella's. I have been looking to ditch my ts ducts because of the poor light output. As I understand it, you installed them to the bumper frame and then placed the TS over them?
Old Apr 3, 2010 | 07:13 PM
Bill Verburg's Avatar
Bill Verburg
Nice!, whats the battery weigh?
Old Apr 3, 2010 | 07:20 PM
jdistefa's Avatar
jdistefa
Nice work, tres tasty .
Old Apr 3, 2010 | 07:39 PM
sanyata's Avatar
sanyata
Yes... more on the Hella installation. Maybe a pcture of the backside. Are they OEM ducts?
All very, very nice!
Old Apr 3, 2010 | 07:57 PM
tdarby's Avatar
tdarby
what brand pedals?
Old Apr 3, 2010 | 08:17 PM
993C4RS's Avatar
993C4RS
Thanks! they spray "candy black" or transparent black.. the more "passes"
they spray, the darker the effect. they consider mine 1 pass.
As advertised, 26 lbs... my bracket, 12 oz.
Originally Posted by sanyata
Yes... more on the Hella installation. Those are xenon, right?
Thanks! but not xenon... they will also work, but these are regular H3's
I think they were like $130... the xenon were to pricey for me!!!
As far as install...
here's more pics... difficult to see when black!
I mounted the lights with the supplied brackets, (which also needed to be
massaged a bit), in the bumper, and aimed them so that the T/S duct would
mount over them like a cover. I had to massage the duct a little on the inside
to make them perfectly flush on the Hella. I read the other DYI with these
lights but I didn't want to trim the fog light housing, or bolt them, or glue them
to the T/S duct. The little mounting tab on my ducts broke a while back,
and I believe it was b/c the weight of the cheap 35w fogs mine came with.
I also found out the "aim" was perfect. (or the beam on the ground)
File Type: jpg
File Type: jpg
File Type: jpg
Old Apr 3, 2010 | 08:19 PM
993C4RS's Avatar
993C4RS
Originally Posted by tdarby
what brand pedals?
these were a Rennlist group buy a while back. Ultimate Pedals.
Old Apr 4, 2010 | 12:01 AM
Cactus's Avatar
Cactus
Noodle Jr.
Everything = Nice!
Old Apr 4, 2010 | 01:23 AM
chris walrod's Avatar
chris walrod
Guru
Rennlist Small
Business Sponsor
nice work!! Really like the updates!
Old Apr 4, 2010 | 08:07 AM
ABCar's Avatar
ABCar
That Hella installation...Really clean.
Old Apr 4, 2010 | 08:20 AM
Macca's Avatar
Macca
Awesome work. Love the well thought out modifications. Brilliant execution.Love to see a shot of the whole interior....
Old Apr 4, 2010 | 08:48 AM
Flying Finn's Avatar
Flying Finn
King of Cool
Nice, subtle updates, great job!
Old Apr 4, 2010 | 09:20 AM
AOW162435's Avatar
AOW162435
Seared
Great job on the Hella lights. They are nice lights, and hopefully will give you a few years of use. I've gone through three (3) sets on my '01 4Runner - moisture works its way under the rear rubber cover and allows the magnesium housing to simply rot away into a mess of white powder. Hella has been kind enough to replace these over the years.
Andreas
