993 Forum 1995-1998
Need help removing interior trim Piece
Old Mar 17, 2010 | 05:43 PM
RDS928S's Avatar
RDS928S
Default Need help removing interior trim Piece
Gents,
I want to remove this taddy cheap vinyl trim peice to be recovered in leather . Cant find any screws? Can anyone help
Thanks Rich
Old Mar 17, 2010 | 06:04 PM
steve porter's Avatar
steve porter
Just been through this , Its glued on and then trimmed to size. the metal piece does not come off
Old Mar 17, 2010 | 06:09 PM
ZombiePorsche44's Avatar
ZombiePorsche44
I just looked at mine and it seems to be held in place via a track or clip system on the back...............
Maybe someone who has pulled a 993 interior while building a track car will chime in..............
Good luck...................ZP44
Old Mar 17, 2010 | 06:27 PM
TheOtherEric's Avatar
TheOtherEric
I didn't think this piece comes out. I replaced my vinyl by gently removing the old (which is hard, since it's glued to foam underneath) then gluing in new vinyl. I only did it to change colors.
If you start mangling up the foam, you probably want to just pull of ALL the foam then install a new bit of super-thin foam (like maybe 1/8" thk).
Old Mar 17, 2010 | 06:30 PM
RDS928S's Avatar
RDS928S
Oh Man, that sucks-wont come offf? WTF
Old Mar 17, 2010 | 06:31 PM
hutch's Avatar
hutch
It does not come out it is part of the body, it's just covered with the material of choice.
Old Mar 17, 2010 | 07:02 PM
RDS928S's Avatar
RDS928S
Ok what are the options?
I hate that cheap piece of vinyl.
Rich
Old Mar 17, 2010 | 07:13 PM
steve porter
Rich
It needs to be covered insitu , any trimmer could do it pretty quickly.
Old Mar 17, 2010 | 09:30 PM
Stealth 993's Avatar
Stealth 993
That whole panel comes out. You got to remove the rear shelf & you will see the screws holding it in. Then there is a track on the top that keeps it tight on the window.
Remove rear shelf
remove screws/bolts
pull up to release the track.
Old Mar 17, 2010 | 09:47 PM
tjangi's Avatar
tjangi
Can of worms ?
Old Mar 17, 2010 | 10:55 PM
1pcarnut's Avatar
1pcarnut
Remove rear shelf
remove screws/bolts
Are you sure you're talking about the same piece that's in the picture? This is the vertical piece on the door jam.
Old Mar 18, 2010 | 11:41 AM
RDS928S's Avatar
RDS928S
Its the vinyl vertical trim piece running next to the door rubber seal. My car is a cab.
Thanks Rich
Old Mar 18, 2010 | 11:57 AM
Stealth 993
It's part of the rear panel, it all comes off in one piece.
Old Mar 19, 2010 | 01:09 AM
budge96's Avatar
budge96
This isn't a piece of the rear package shelf..this is attached to the door jam and isn't removable, the vinyl
trim is cut to fit and glued and can easily (somewhat) be replaced with leather of your choice...Bert
Old Mar 20, 2010 | 12:22 AM
jhubs's Avatar
jhubs
Just leave it alone, it is glued on and you will screw it up if you try and remove it. Call your local leather doctor... call your P-car dealer or wrench and ask who does their custom leather dying. It is very inexpensive to have it colored.
See photo of my 1987 911 below. After it was dyed to match the new leather and vinyl, you could not tell the difference.
File Type: jpg
