What`s missing ?
hi guys, last week when doing an oil change, I noticed what looks like a missing inspection cover. should there be one ? I have looked in my manual but can`t find a picture of said area. thanks steve
Second that. Check the engine bay, is the rubber snorkel to the airbox there? If not the clutch breather/vent has been removed. This as it says vents gasses etc and helps cool the clutch. Not a massive problem, but the hole needs dealing with in my opinion.
There's the rubber snorkel at the air box attached to a metal tube with a flex hose at the end. I think there's still a part missing like a hose end to attach to the trans. Can't seem to find that in the PET CD, but here's the unit to the air box:
Thanks guys, the hose at the airbox is there . I didn`t realise where it went, or used to go before i had the new clutch installed last year . i will source new parts and go back to not letting anyone touch my stuff again, thanks again steve
be kind to your mother
your wife is always right
993`s look horn
and dont let just anyone touch your car
mark if you have, or can supply that part can you include it with my order, otherwise i will have to get it from O.S anyway steve
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I assume "horn" is a good thing
unfortunately, the fitting isn't readily availble. Not sure what else they left off... most likely the hose that connects to that fitting is also MIA. The 2 pieces above that are likely there but as Eric said, you have to take a peek.
Chris, get some rest!
good tips!
