Immobilizer Code
Thanks for that link. It had me check the P-Car site again where it clarified the differences in programming depending on the model year.
Well even if they flat bed it, they're going to have one hell of a time starting it thereafter. Maybe they can sell it as a paperweight.
Even if the immobilizer turned out to be a problem, I could get the control unit reflashed to eliminate it.
My two cents says "programming" the immobilizer won't do any good.
Try this: Turn ignition back on, press immobilizer, then turn off ignition. Maybe do it two or three times, then try to lock your car with the immobilizer.
If that doesn't do it, turn the igition on and off severl times; when you remove the key make sure you get a solid "snap" as the key is removed. Then try to lock your car with the immobilizer.
If that doesn't do it, close the car door and wait several minutes and try to lock your car with the immobilizer.
Try your spare key, it may make a better contact inside the keyway and lead to a more positive uncoupling when you remove the key.
My ignition switch will occasionally "cry" when I remove the key....not the chime sound, but a fading cry.
My immobilizer problems come and go. Right now working fine, but a month ago it did the same as yours. I think the trouble is somewhere in the ignition keyway.
Gordo
Gordo
Great Advice! Thank you.
I went into the garage just now and just played with the Ignition cycling it on and off over and over, Then I pulled out the key Waiting for the loud "Snap" and pulled the key out with pressure on it to the counter clockwise side. Raised my hand to get the remote a little farther from the car and it worked from the first time. I then Cycled the immobilizer by arming and disarming it 5-8 times and it worked every single time. Im so happy right now...............
Now hopefully it stays working, but from now on I will defintaly pay more attention to the ignition.
Folks, a lot of problems are blamed on the IMMOBILIZER (sometimes rightfully so) but can, in actuality, be the clutch microswitch at the base of the pedal assembly. If the switch is bad and won't send a signal that the clutch pedal is depressed, the car won't start. In order to take out that variable, you can just by-pass the switch but, if you do, either keep depressing the pedal when starting or be absolutely certain your car is in neutral.
The service manager at my local dealer is the only person that has access to immobilizer codes through Porsche and they are not to be handed out.
As for key codes, that is another matter. He is getting that for me.
If one cannot start the car using the remote, the key code is what is used to start the car using the key to enter the code via the ignition switch by the number of off-on cycles of the key based on the key code. I believe I have that right.
I keep my 993 in its own separate garage stall, which has no man door to the outside. The garage door opener is kept turned off. The man door between the stall and the rest of the garage has a dead bolt, and sits in a reinforced frame. I can also place a 2 x 4 between the garage door top and the roof joists. It's just a bit of extra security.
