993 Forum 1995-1998
4L big bore kit??? anybody
Old 02-25-2010, 08:56 PM
Magdaddy
Magdaddy's Avatar
Default 4L big bore kit??? anybody
OK-gathering info on a 95 C4-lots of nice mods- and theoretically...a 4L big bore kit.
The motor was installed by this dealership back in 99-the first owner apparently had it assembled somewhere else.
I searched-can't find any reference to a 4L kit.
The dealer has cleaned up a lot of issues-but still no details on the motor. That is the 800 lb gorilla, stopping me from more seriously considering the car.
So, anybody have any insight on the big bore kit?
Old 02-25-2010, 09:08 PM
993_Pilot
993_Pilot's Avatar
CMW Motorsports used to make a 4 liter kit and billet heads too, but I don't know much about them. 9Meister does 4 liter upgrades too, but if the car is on this side of the pond, it probably isn't theirs.
Old 02-25-2010, 11:02 PM
race911
race911's Avatar
Mat Lowrance out of Reno/Truckee briefly ran a 4L in his race car. Back now to a 3.8L I'm not sure exactly what failed/was failure prone, but I don't think he was happy with non-Mahle pistons. Mat is ex-IMSA from the '80's, and pretty much wins all the PRC races out here overall. Last year at Sears, he kept two Grand Am spec 997 Cups in his mirrors............
Old 02-26-2010, 01:43 AM
blackcat
blackcat's Avatar
Pacific Power Motorsports was running a 993 w/ a 4.0L motor a year or so ago (maybe it's 2 years ago now) - I wouldn't call it a kit, they were using rings from a Chevy that they'd massaged
no affiliation, they are a PCA GGR sponsor tho fwiw
http://pacificpowermotorsports.com/
Old 02-26-2010, 02:44 AM
VMXWinn
VMXWinn's Avatar
Eric is a great guy and good to deal with.
+1 for Pacific Power Motorsports.
Old 02-26-2010, 11:29 AM
race911
race911's Avatar
Probably should stop by there sometime as they're basically right across the freeway from my shop. Not that I have a shop. But with the amount of personal projects popping up a casual observer probably wouldn't know it.
Old 02-26-2010, 11:44 AM
NineMeister
NineMeister's Avatar
I've run a 4.0 litre engine in my 993RS & customer cars since 2006. The 9m 4.0 litre engines run a 80.0mm crankshaft with 103.0mm bore (=3999.5cc) and we use this combination because it utilises the largest cylinder diameter that we consider to be completely reliable in race conditions.
I believe that other tuners use a 105mm bore with the 76.4mm crank to give 3970cc (or 104mm for 3895cc), but I would not use this combination as I have grave concerns over the stability of the cylinders at this diameter.
Old 02-26-2010, 11:48 AM
Mark in Baltimore
Mark in Baltimore's Avatar
Even if done correctly, how likely is it that a 4.0L motor would grenade in under 40 hours when used for track work?
Old 02-26-2010, 12:46 PM
NineMeister
One of the first 9m 4.0 litre engines is racing in a 993RSR in South Africa - I crated the engine over and it has not been touched in 3 seasons, which is well over 50 hours. My engine ran has run for a similar mileage and has just been stripped to use some of the parts in another project and everything looked perfect. Likewise the first one we built is in the back of the white 9m64RS Clubsport which has been used around the N'ring & Spa for over 3 years without touching it. Does that answer the question?
Old 02-26-2010, 12:48 PM
jdistefa
jdistefa's Avatar
Colin,
Just tells us that not every 4.0L kit is created equal
Old 02-26-2010, 12:52 PM
matt777
matt777's Avatar
As with all engines, power is made by keeping the bores round. Thin cylinder walls aren't a recipe for more power.
Old 02-26-2010, 01:20 PM
bart1
bart1's Avatar
I can tell you boys, if I had massive funds, Mr. Belton and his magic elves would do some work on my car.
Old 02-26-2010, 01:35 PM
Magdaddy
Magdaddy's Avatar
Default this 4L build
was installed in 1999, and has 30K miles on it. I don't believe the car saw any track use, cause it's pretty clean...at least with all the pictures I've seen.
So, an 11 year old 4L build, with 30k miles on it...that drips(ever so slightly) oil, according to the dealer. Probably should be no surprise that it's been on the lot for almost one year.
The car is awful pretty though. I still hope to get specific build details about the motor. The first owner is still a customer at the shop-someone built the motor for him, the shop simply installed it. They are going to contact him to hopefully get more detail info.
Until another car comes available to draw my interest...this one is it.
Old 02-26-2010, 01:43 PM
matt777
matt777's Avatar
I'd be next in line.
Old 02-26-2010, 01:54 PM
NineMeister
Thanks boys, that's reassuring.
Magdaddy, are you sure that the car you're looking at is not a 3.9 with just 104.0 bores? If so, worst case is that you may have an engine with oval cylinders and can simply replace them with new 104's or even go back down to 102's or 103's.
Quick Reply: 4L big bore kit??? anybody
