993 Forum 1995-1998
replaced lower valve cover seals
Old Feb 6, 2010 | 05:12 PM
JimGinKC's Avatar
JimGinKC
Default replaced lower valve cover seals
went pretty smooth - had help from some of my kcws friends, so it went pretty quickly.
Old Feb 6, 2010 | 05:20 PM
cdmdriver's Avatar
cdmdriver
Awesome, just did mine last week. Did you pull off the heat exchangers or just work around them?
Old Feb 6, 2010 | 06:24 PM
JimGinKC's Avatar
JimGinKC
worked around them with a sawed off 5mm 1/4" drive socket
Old Feb 7, 2010 | 01:32 AM
gm1160's Avatar
gm1160
I was just quoted a price of $300 for installing new lower valve covers. Is that a decent price for this install?
Old Feb 7, 2010 | 10:29 AM
JimGinKC's Avatar
JimGinKC
does that price include the new covers? how much of that quote is labor?
Old Feb 7, 2010 | 10:48 AM
boulderbobo's Avatar
boulderbobo
Did you happen to take before and after pics?
We would love to see the results of your handywork
Bob-
Old Feb 7, 2010 | 11:11 AM
JimGinKC's Avatar
JimGinKC
Sorry - I should have! we just jumped in, and it was back together before you know it.
I am documenting today's wrenching...stay tuned
Old Feb 7, 2010 | 02:23 PM
boulderbobo
Ok. We'll let it slide this time
Old Feb 7, 2010 | 05:06 PM
gm1160's Avatar
gm1160
Thats just the price for labor. The new aluminum covers are $315 on pelican.
Old Feb 7, 2010 | 07:51 PM
JimGinKC's Avatar
JimGinKC
it didn't take us very long - for that much labor, you might just buy the tools and DIY
Old Feb 7, 2010 | 10:12 PM
JPS's Avatar
JPS
I look at it differently...for only $300 if they will do that, probably worth it unless you really consider yourself a wrench. If you've just changed your oil and are looking for the next thing up, this isn't hard, but some of the bolts are hard to get to and sometimes hard to loosen. For $300 I wouldn't have messed with it (I did 1 side only)
Old Feb 7, 2010 | 10:29 PM
JimGinKC's Avatar
JimGinKC
that's true, but this really is not a difficult repair. You need a 1/4" rachet, a 5mm allen socket that you cut down to the same length as the short part of a standard L shaped allen wrench, and the L shaped allen wrench. remove the rubber boot between the heat exchanger & the heat tube, disconnect the spark plug wires, and take out the 11 allen screws. there are only 2 screws that are trickly to get at, and if the socket won't fit, the L wrench will.
if you can change the oil & filters on a 993, you can do this. $300 can go for a lot more fun stuff than this labor
Old Feb 7, 2010 | 10:35 PM
Dudley's Avatar
Dudley
$300 for labor is a fair price for this job. IMHO
Old Feb 7, 2010 | 11:50 PM
PorscheDoc's Avatar
PorscheDoc
That 5mm allen socket was not cut down, it is just a snap on stubby allen socket 1/4" drive :O)
Old Feb 8, 2010 | 09:45 AM
993Porsche's Avatar
993Porsche
Has anyone experienced stripping any of those allen bolts? If so, how did you get them out?
Ken
