Icy, Cold, Snowy day...had to warm her up
One recommendation: After the car has been sitting for more than a few weeks, or during an oil change just before you fire the engine up, pull the DME, crank the engine over til you get good oil pressure, then put the DME in, and start the car. You are guaranteed that oil is everywhere it should be. If you are totally paranoid, you can even do this once in a while when it stored.
I have seen cylinder walls with light rust film after cars have sat for a while (yes, on 911's) so I think it more important that the engine be turned over once in a while. Starting is another issue, there could be a fair amount of moisture condensed without a good heat cycle, so make sure if you do start it, it gets warmed up. Throw a blanket over the grill when its idling, that seems to help quite a bit.
Personall, I think it does nothing for the car and/or engine to start it up cold and leave it idling. My opinion is either drive it or store it. Just make sure you stabilize the fuel, have good tire pressure and a battery maintainer. The latter to me is the most important, 993's just sitting there use power, so any battery wil go into a deep draw over the storage time, so a battery maintainer means that the battery is charged even with the natural resistance of the battery combined with the 993 draw.
Cheers,
Mike
Cheers,
Mike
Is there a couch around here? ![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
I think I need a psychaiatrist...oh, wait, I have to rev up my car. Be right back!
Oh sh-t...was that rust shooting out of my exhaust pipes?
993 for sale...never started below 40f. Mufflers in pristine condition, inside and out. best offer.
This is BS, so long as you get the motor up to temp.
But I can see this turning into another one of those pointless, neurotic threads, worthy of a Woody Allen movie. Previous such threads include:
1) Should I start my car during winter storage?
2) What RPM should I drive it at?
3) What gear should I use at ___ MPH?
4) How long should I let the engine warm up before driving my 993?
5) Will I destroy the value of my priceless, irreplaceable 120K mile 993 by having the front bumper resprayed for rock chips?
6) Will I destroy the value of my priceless, irreplaceable 120K mile 993 by replacing ____ part with an aftermarket one?
7) Which is best, a 964, a 993, or a 997?
8) I installed a strut brace and IT TOTALLY TRANSFORMED THE HANDLING OF MY 993!!!!1
9) What tires should I get for my 993? I only drive on the street and this choice is 99 percent irrelevant, but I want to feel like I'm a skilled driver and can tell the difference between $400 tires and $100 tires.
10) Which tail should I get for my 993? I only drive on the street and this choice is 100 percent irrelevant, but I want to feel like I'm a skilled driver and can sense "aero" mods on my morning commute.
Etc.
Etc.
Just wondering....
Terry
And of course the "I'd hit it" thread.
Etc.
Etc.
Beautiful and I have one to add:
All 993's should have (or need) a top end rebuild at 70K
Mike
2nd. If the car sits for a long time pull the dme and crank till you get oil pressure and start it up. As long as the oil gets up to temp your fine
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
In the winter time, I replace my engine oil with something thinner, usually WD40 or baby oil. That makes the cold starts so much easier on the bearings, plus it helps to clean things out inside the motor. You can get WD40 in gallon size at the hardware store.
Btw, Noah, my strut brace completely transformed the handling of my car....esp on driveways.
