Front control arm bushings - Replaced & Fantastic!
Thanks much to Chris and Robin... they installed new bushings over the weekend and the transformation is VERY noticeable.
No more wobble, much more stable. Over the past few months, I thought I was having a tire problem and had the fronts rebalanced twice to no avail. Figured it had to be the bushings, and sho nuff I was right!
Cougar's about to roll over 180k miles and she rides like a dream!
Do you have the DIY on this? Like to see what I'm getting into first. Thanks
I noticed a similar improvement when I replaced the front bushings in my car. The improvement was not subtle. Truth be told, I went with the 993 bushings from Elephant Racing on the recommendation of my mechanic, but I'm sure Chris's bushings would have had a similarly positive effect.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Thanks for the kind words!!
Yes, many 964/993 suffer from random wobbles that these bushings typically cure. We did a 15k mile 993 that had failed std bushings. Its an age thing not so much mileage.
Scott, send me an email at cwalrod@sbcglobal.net and I will email you the diy.
I found that they made a difference even though I replaced perfectly good factory bushings. I would recommend the exchange arms for anyone not interested in doing some dirty grunt work. Removing the metal sleeves is a pain.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I would agree, especially without the use of a press.
With the press tools I've made and 6-10 tons of force, they slide out in seconds. I know this will irritate those who have done this via hacksaw blade and chisel/punch. I know it did **** me off after doing many many of these the hard way![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Control arms from West coast cars take about 6 tons, East coast control arms 8-10 tons -- I kid you not.
You mean I could have swapped out my control arms and gotten a replacement set with your bushings installed???!!! After spending the last 3 days wrestling with mine, I would definetly receommend getting them already installed. BTW, I have a midwest car Chris...Im sure mine would have taken about 100 tons of force for your press to extract those mothers! Corrosion Plus!
There is no great honor in having done this job myself...It is just alot of hammering, sawing and wrestling.
Chris, please e-mail me the DIY as well when you get a chance.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Robin is now hosting the DIY on p-car.com
The press force needed is due to the amount of corrosion between the steel sleeeve and the control arm casting. Amazing!
