Finally, an alternative to Bilstein HDs!
#91
Martin, are you looking to sell?
I used stock drop links for my M030 RoW set up...connected to M030 22mm front sways, and 21mm 993 Turbo (Euro) rear sways.
This is a sweet set up, and cheap too. I only took it off when I had the chance to get a used set of PSS9s.
Now I use the PSS9s, TRG sway bars and Tarrett drop links...this is a pretty good set up too.
#92
I think Koni Sports are height adjustable though
I know the rebound setting is adjustable
Just checked and Koni USA says the rears are still not available!
I thought I saw more info here a while back too
#94
#95
http://www.tirerack.com/suspension/S...lar=&brand=all
I'm hoping you all are wrong.
#96
^^ yes, I'm hoping you're correct as well. It would be nice to have more options as I suspect the FSD's + R.o.W. springs set the car too high with no ability to adjust ^^
#97
#99
Actually, my car has R.o.W. M030/Monroe suspension and the ride height is perfect for a street driven Cabriolet. However, about 2 weeks ago, I was over at FD Motorsports and saw a coupe they had recently installed a Koni FSD/R.o.W. M033 Suspension on and I noticed that that cars ride height was quite a bit higher than my car, so I'm questioning if the difference could be between the FSD struts and the Monroes as opposed to a difference in ride height created between using R.o.W. M030 v.s. M033 Springs which I thought were the same height-wise.
#100
We have in stock the Sport Yellow (Front and Rear) and FSD for the 993.
Your Porsche Parts Superstore
Parts | Tech-Session | Facebook | Youtube
Jason Burkett
Paragon Products - Porsche Parts & Accessories*- 800.200.9366
Tech Session - Porsche Tech & Info*- 361.289.8834
jason@paragon-products.com
Jason Burkett
#102
3rd Gear
Koni Sport Adjustable install with M030 kit
I am currently completing an install of Koni Sport yellow adjustable shocks and struts and Porsche M030 springs (f & r) on my '97 993 narrow body car. I sourced the Koni gear from Jason at Paragon. A little bit of a wait but they arrived as promised - thanks Jason for the support.
Here's my experience and comments. I started with the rears. The Koni rear shock struts are not height adjustable. Neither are the stabilizer bar drop link mounts. They essentially match the stock suspension dimensions. And therefore are not compatible with RS adjustable rear stabilizer bars. Porsche however accounts for suspension height and spring rate tolerances with spring shims available from 3 to 8mm in height. See the 993 workshop manual or PET for part nos. All shim sets are still available. I was told by a Porsche tech to just install what came with the car. Mine had 3mm spacers on the rear strut assembly. The manual states that the number of colored stripes on the spring dictate the shim thickness to use. I bought an 8mm shim set based on this instruction but didn't use them figuring I would error on the low side of ride height. The M030 springs are too short to require any compression upon mounting in the strut assembly. In fact, unloaded, the spring just flops around until mounted onto the car. This appeared to be a concern until I loosened and re-torqued all of the control arms to 'zero' or neutral position. This is explained in the Porsche workshop manual where the toe-in control arm should be at a horizontal position to the ground when tightened. This automatically provides some spring tension from the rubber bushings being torqued as the spring strut assembly is mounted in the car. Essentially, the Koni gas strut is compressed to the spring length by the suspension bushings. Even with the wheels mounted, the the spring stayed in place. Go figure. I mounted M030 rear stabilizer bars with the stock drop links. It fits without issue.
Next, the fronts. The Koni fronts are somewhat height adjustable but the threads do not extend near as low as the Gert-supplied Bilstein HDs. A previous post on this forum detailing the install of M030 springs and HDs references 63mm setup distance between the lower lock ring and the top edge of the mounting bracket. This, it is said, should approximate a starting point for ROW Sport ride height. You can't get anywhere close to that measurement with the Koni Sport struts. The lowest it adjusts is 85mm. Not sure if this is a problem but it does preclude lowering the front of the car to mimic RS ride height for sure. I'm still making slight adjustments to match front and rear ride height to equate the +/- from Porsche spec. using the current rear height as the set point. I installed RS adjustable front stabilizer bar with RS drop links.
When I get a chance, I will post some photos if you are interested. Right now I am finding it difficult to locate a shop with kinematic toe-in tools to complete the alignment. As part of the suspension overhaul I replaced nearly all bushings with ERPs (yes I also replaced all the lock nuts with new). So I am sure that many of the eccentrics are off with the change in ride height.
Summary: Koni Sport adjustable shock sets are available. They do work with M030 Porsche springs. I have no report on performance or final adjusted ride height front and rear.
#105
if the rear shocks are not adjustable then there really is no concern with the amount of threads on the front struts. The adjustment is used to corner balance the car... that's it.
I am curous to see the final ride height after align/CB is complete...
Pics please!
Pics please!
