Big tires under a "stockish" 993 WB
Just as an FYI i'll let the group know that yes, you can use "grossly swollen" tires under a near RS ride height WB.
I recently acquired a set of 996 TT wheels (in SY!) shod with NT01s (Thanks Chris W !).
Rear tires = 315 - 30 X 18
Front tires = 245 - 40 X 18
I was primarily interested in the wheels, but could not resist seeing if the tires would fit without rubber-to-sheetmetal contact.
I did some testing on Saturday and an AX on Sunday with no fitment issues.
I'm not saying these sizes of tires is a good idea................
just letting you know what's possible.
My car has -2 degrees camber front and rear.
Ride height = RS +10mm
Fenders are NOT rolled
Rear tires work with no issues, i think i'd feel a bit more comfortable if fronts were 245 - 35 instead of 245 - 40.
Cheers
Craig
No comments about the lovely color combo.................. please.
Even for track wheels, SY and Iris Blue is barely tolerable.
Cheers
Craig
What tire are you running 315? I'd like to look up what the tread / section widths are. I've been thinking of running Kumho's 305 or Hoosier's 315 next season. Hooser 315 A6 have a section width of 12.5" and Kumho V710 have a section width of 11.8" on their 305s... now when you look at the Michellin PSC for a 295 your at 12.1"
I think remember reading WB folks running 295s for the pilot sport cups which would hypothetically mean I could run the 315 A6 and have no issues. Plus I'm betting whatever 315 you have is probably wider than the A6 315
