Window Rust
At the top of the rear window on both sides, it is under the third brake light bar, so I pull it up on both sides to that point and let it lay on the window for a day or so (in garage) to allow the channel to dry out (after I blow out most of the water collecting in there).
I then snap / push it back in place with my fingers when dry. The seal / trim gasket will stretch, so it takes a little shifting to get all the gasket / trim to snap and lay flat in the full channel. I start from the top on both sides and meet in the middle of the bottom of the window. That usually results in some "extra" gasket (humped up) in the middle. I then work backwards out from the middle to the corners and the excess works it way back out. The gasket / trim seems very elastic.
Then I usually (wearing a glove) push really hard with my thumb to snap the gasket into the channel all along the gasket on both sides. It kind of goes concave when it snaps in.
I will now explore the front windshield to see how it is done. I have noticed water being blown out from under the gasket in the past. YMMV
Porsche has paid for this fix in the past. When I got my car a few years ago I investigated and found that several dealers in the U.S. (I'm in Canada) had got Porsche to pay for the repair as it was a factory defect. I managed to get mine repaired by Porsche within 2 months of the rust warrantly expiring.
Not sure if it's possible - but perhaps finding a dealer willing to fight PCNA to get them to pay for it (or some of it) may be helpful.
*seeing the huge amount of rust on this posters car is shocking and i don't think i've ever seen this amount of rust before...most cars just have the lower front windshield rust
i have one small rust area in my lower front windshield by the drivers mirror,,,it is not rusted thru just surface bubble.
the guy who will be repairing it quoted me $650 plus $150 to remove/replace windshield...this includes the prep and paint...he is excellent painter who can blend any metallic paint and that is the key when repairing a metallic color car...
painters who are not good at blending want to spray the entire top portion of the car when doing this repair and it gets up into the $2000 range.
*i've seen excellent painters spot paint tiny areas on hoods and doors on metallic cars...they use an airbrush and it looks perfect when finished.
Pay me now or pay me more later..................this is part of owning a 15 year old Porsche.
Would it be feasible/possible to fill the gap between the body and windshield seal with silicone? I just dealt with a small rust spot in the lower corner of my windshield. Then washed the car & pulled back the seal. Lots of water came out. Seems as though if there is no way for the water to drain, either the seal must be pulled back each time the car gets wet to allow the water to escape, or the gap needs to be eliminated.
Thoughts?
Thanks,
Paul.
Hence my suggestion of filling the whole gap with silicone.
Only issue I can see is removing all that silicone when installing a new windshield.
As a previous poster said it is likely that a previous windshield fitter has scratched the finish when cleaning the old gunk off and not repainted before fitting the new screen. Then the rust starts on the scuttle under the screen. Also the outside rubber seal can rub the paint away if the screen moves and start surface rust there. It is not Porsches fault as such.
As far as sealing around the screen and keeping water out, I sprayed a good amount of Valvoline Tectyl ML into the gaps around my front and rear screens. ML is like a penetrating rust preventer that then cures to a waxy finish that does not move.
I bet if you have an original front or rear screen then you will not have rust. I equally reckon that if you have either replaced in the past then there is a reasonable chance that you will be dealing with rust at some point unless the area was properly painted before the new screen was fitted. Fat chance of that unless it was a specific instruction and a paid for activity.
By the way in my car which is a 94 with 185k on the clock and has been outside all it's life in the UK has no rear screen issues at all (original screen) and some minor front screen surface rust (replacement front screen).
My screen will be coming out soon and will have the surround and scuttle properly treated and painted before refitting.
Berni
Although rust is showing on one corner only, I might ask them to somehow protect the other corner too, maybe epoxy paint? Any suggestions what can be applied on top of the paint to provide a better rust protection?. I can't avoid the water living in the Northwest and drying the corners by pulling the rubber seals everytime is PIA.
Thoughts?
Thanks,
Paul.
I use a black windscreen sealer called 'ezycaulk'. It's a pretty standard window sealer for cars. It is very easily removed when dry and if your window man puts enough of it in when he installs the screen, there's nowhere for the water to get into.
I do my own screens and use this stuff. no rust problems.
Be warned, very messy stuff when wet. A little bit goes a very long way. Best to leave it till the next day to scrape off what squeezes out of the seal. I use a piece of soft plastic and a rag with some mineral turps on it.
The nylon on the bottom corners of my rear window had cracked and broken off and the outer seal was peeling up. Pete
