After Market Sparkplug Wires?
Does anyone have any experience with third-party spark plug wires or are OEM the only way to go? I need them right now. Although my car still runs fine, some of the metal strans have popped out from the rubber insulation. After cleaning it and around the area, I covered it with electrial tape as an temporay fix. Also, what's the best way to install those wire?
Ken
Ken
I have replaced individual wires purchased at a very reasonable price from Mark Robinson [porschesolutions@gmail.com] "no affiliation", and have had no problems.
Do a search, and you will find many references to Mark.
Seared
Br. Ken,
I think the general consensus is to go with OE Porsche wires made by Beru. You can purchase individual wires from Sunset if only the lower ones are bad. You may wish to consider making a day of it and removing the intake manifold to gain some much-needed access.
Hell, if you schedule this procedure with my shop, we can go ahead and remove that pesky SAI system.......
Andreas
Andreas
Agent Orange
Mark's wires are same are Beru, same as OEM just red in color. I don't know if he sells individual wires however.
In the broader picture my concern with buying wires only is that you still need to change the plugs and that negates any savings. Plugs fail almost at the same rate as the wires so changing the wires and not the plugs is not the answer.
if you are doing a complete replacement, OE Beru wires are available already strung in their looms and ready to install.
Porsche only sells the individual wires and does no carry the packaged, "pre-strung" Beru set.
Thanks everyone; great advice as always.
Ken
Seared
Walk in the park. Cactus and I started on his shortly after midnight, after an evening that involved the picture below. I think we finished around 4:30 am...
Andreas
No freaking way. That has to be at least a case or more. And you guys still finished the car before passing out that morning? Darn, I'm impressed. Ok, what kind of plugs do I need to order? I'll get started buying the wires today. I also need to clean that engine before I see the GQs (i.e. garage queens). Hopefully I won't be embarrassed to much. The valve covers are leaking like no tomorrow. So, where can I pickup some of that Xennit (SP) or whatever it's called solvent cleaner?
Ken
Ken
The Magnecor wires are high quality, no-BS wires. Ends are bonded on. Had a set on my 931 but have not purchased for 993. Price is competitive with stock but I don't know what sizes they sell (wire diameters) - you'd have to squish them into the existing holders.
dave
dave
