Dropped Tranny / Clutch looks good?
Seared
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
I'm still a bit travel tired... fixed it.
Though both appear to be "lubricants"
Hi Matt:
Congratulations on your impressive project. I look forward to seeing the pictorial later. Did you ask any of the local indies or the dealer, if they would give or sell you a few ounce of the Olista?
Anyway, I hope the cleanup cures the problem.
The tranny drop is pretty straightforward with the DIY instructions. You just need the XZN/triple square/serrated bit set to remove the flywheel and pressure plate bolts. A selection of jacks helps too. Of course you need to remove a whole bunch of items before you can drop the transmission. The starter, slave, axles, shifter, throttle cable, reverse harness, transmission mounts, air tubes, oil return line all have to come off. If I had to do it again (which I hope I don't
Can you please elaborate some on the hanging clutch on decel issue? What does this feel like? I'm wondering if this is happening to me and what caused me to not be able to downshift from 6th to 5th and then to 4th on two long, hot, high-speed hwy. trips this past weekend.
https://rennlist.com/forums/993-foru...e-problem.html
https://rennlist.com/forums/993-foru...put-shaft.html
https://rennlist.com/forums/964-foru...t-of-gear.html
