Dropped Tranny / Clutch looks good?
I dropped the tranny and pics will follow very shortly. I award a bravery medal to anyone who did this job on their back. There is a lot of parts that have to come off to drop it and many bolts are not easily accessed. I used a 4 post lift and a tall tranny jack. The engine was supported with the jacking tray and a bottle jack. Thanks to Andreas and Nsully for their DIY post.
Everything looks in mighty fine shape (70k miles) If you saw my other posts the clutch was not disengaging properly on decel. The disc, housing and flywheel all look very nice.
The RMS is nfg and leaked. I put a screw in it and used a slide hammer to yank it. Works well. I love hammers.
The transmission and clutch disc splines were pretty dry with some slight surface rust. What grease was left was on the ends and hard. I can't be sure that this was the problem. I measured the disc at 8.4mm. I wonder what new/retirement thickness is.
I'm being cheap now and wondering whether I should put it back together with a new RMS, or just replace the clutch or replace the whole lot including the DMF. The face on the DMF is flat and in surprisingly nice shape. I will be p*ssed if I cut a corner and have to do it again but I don't need to spend $2k unnecessarily as I've got other projects on the go. Pics to follow!
One thing is for sure - I will be checking the p/s belt as now is the time. I sure hope the starter lasts a long time because changing it out would be near impossible without lowering the tranny I would think. I did this job by myself except for pulling the transmission off. It could be done with one guy on the lift.
Matt,
With 70K on the car I would do the clutch now. I does look like it was treated well though... the disc is in good shape.
The thickness of the disc is not the only factor.
The DMF could go 25K more miles or start giving you trouble much sooner.
The PP could also fail sooner rather than later.
How does the T/O bearing feel?
Your hanging issue is very likely the crusty spline. Clean up with some steel wool and/or a fine wire brush then make the decision: Dry or lightly lubricated.
Lubrication attracts clutch dust... dry, well, you see what can happen even when there was a light coat of grease.
I prefer a light lubrication. IIRC, that is what Porsche says to do also... but don't quote me on that.
If you don't mind doing it again later, clean it up and reassemble.
Nice work, by the way
Thanks Mark. The TO bearing feels good. I initially struggled with the spline theory as I've never heard of this happening before. Perhaps it is just a 993 issue. I should just bite the bullet and not have to bother splitting this thing again but....
Do the clutch kits come with the Olista grease and the centering tool? That Castrol Olista grease is impossible to find around here.
Cheers,
Joe
Seared
Matt,
Fantastic job! Your question is a toughy - I'd probably opt to renew everything since it's apart and your car has mileage/age on it. If you were selling the car, putting it all back together cleaned & greased would make the most fiscal sense.
Two questions:
Andreas
Two questions:
- Are you returning the red tool cart?
- How soon can you ship my bravery medal?
Andreas
As Joe also said, you can use a high temp disc brake grease. Doesn't take much.
If you want I could find a way to get you some Olista in a small container.
It really isn't worth buying an entire tube from Porsche unless you are planning on doing it often.
You also want to use it on the T/O fork where it contacts the bearing.
- The red tool cart is useless but I finally found a job for it - tranny washing station (not that kind of tranny but I suppose it would work for that too).
- Your medal is on the way. Just wait by the mailbox.
Seared
"This Product Contains Olestra. Olestra may cause abdominal cramping and loose stools. Olestra inhibits the absorption of some vitamins and other nutrients. Vitamins A, D, E, and K have been added."
Hmm...
Andreas
