high-pitched buzzing from dash
almost exclusively happens with I have the fan on and it occurs intermittently, like a thermostat is turning off and on. Is this an issue with the climate control unit?
its hard to isolate the location of the buzzing...seems omnidirectional. Good thought about the relay, but it would have to be a relay associated with the climate control, right?
are you sure its not the fuel pump??
located under the car but sounds like a buzzing dash noise
Try to check whether one of the multi-conector plugs on the back of the A/C control unit has come lose.
I had exactly the same problem for months, and it turned out to be the one of the plugs on the back of the A/C unit.
It must have come lose when the unit was pulled out at some point.
If it's not the plug, it could definitely be the fan inside the CCU as cy7878 suggested. I had the same problem.
I have the same issue, but on my car I don't notice it when the car is running, but I do hear it after the car is shut off and seems to buzz up to 10 minutes after the car has been shut off? On my car it seems to come from the climate control unit.
