993 Forum 1995-1998
Front brake rotor replacement
Old 09-22-2009, 01:26 PM
Stealth 993
Stealth 993's Avatar
Did you check the tier pressure? 993's are very sensitive to tire pressure. Yea, it sounds dumb & obvious, but it does cause that problem.
Old 09-22-2009, 01:35 PM
flyingchappy
flyingchappy's Avatar
Originally Posted by ship4u
I agree with the front bushings as the likely culpret. My car had a similar issue. Replace the whole thing, MHO.
Best regards,
Don
Don, thanks. Excuse my ignorance, but which bushings are your referring to?
Old 09-22-2009, 01:37 PM
flyingchappy
I am very religious with the tire pressure, I played with lowering and raising it slightly, right now it's 36, 44, front back respectively.
Old 09-22-2009, 01:42 PM
Stealth 993
Then check the bushings, & maybe go out for a fun drive, & hit the brakes hard a few times, engaging ABS, see if that cleans up the brakes & makes it go away.
Old 09-22-2009, 01:45 PM
Uber 911
Registered User
Uber 911's Avatar
Thanks for input. There is no pulsating in the pedal just in the front end and steering. Would this be due to sitting for a long time? The car was last driven by the PO maybe 3 years or more before I bought it.
"The car was last driven by the PO maybe 3 years ago"
So how many miles or usage has the car done/had in the last 3 years?
Old 09-22-2009, 02:08 PM
NP993
NP993's Avatar
If the car sat for three years, you very well might have pad deposits or corrosion on the rotors. I would do a few hard stops from high-speed -- get the brakes warmed up and scrub those rotors off. If that doesn't work, it could be the a-arm bushings, and it could also be the case that the rotors need to be professionally cleaned up.
Quick Reply: Front brake rotor replacement
