Wheel well cleaning - redux
Subscribe
Sep 2, 2009 | 12:07 AM
Thabks for the tip... now I will have to find if these are available in Canada.
Reply 0
Sep 2, 2009 | 12:12 AM
Quote: Thabks for the tip... now I will have to find if these are available in Canada.
http://www.eshine.ca/chemical_guys_b...y_16oz-804.php
Reply 0
Sep 2, 2009 | 02:29 PM
Looks great and makes want to do this myself using stands. Are you doing this inside or outside the garage, e.g. do you need to use a power washer when you rinse off the cleaning material? The reason for this question is because I want to paint my calipers as well, and I dont want to jack up the car twice, once to clean the wheel wells outside the garage and once to paint the callipers inside the garage.
Reply 0
Reply 0
Sep 2, 2009 | 07:14 PM
I am just jacking one corner at a time, but I am sure a more lesiurely, successful method would be to get the car on jackstands, then soak and scrub the wheels on a rotation basis.... plus you'd be set to do your calipers 'while you're in there'.
I did mine in the garage with a drain. Nice flat surface to jack from.
Matt
Reply 0
Sep 2, 2009 | 11:23 PM
Thanks.
Reply 0
Sep 3, 2009 | 06:03 AM
FWIW, buy a gallon of diesel fuel. Paint it on, leave for 2 hours, then using rags, wipe off. Repeat as necessary... it will be!!
Cover floor with a heavy rubber based ground sheet, have LOTS of kitty litter over the ground sheet. Smells are minimized if finishing with Simple Green.
GL
Reply 0
Sep 3, 2009 | 08:48 AM
Best solvent for this area......WD 40. Softens the shmutz on the painted surface for easy removal.
Reply 0
Explore
Sep 6, 2009 | 12:28 AM
Playing with new photo software so I thought I'd post these. Guy (briefscape) came by and helped (OK, more like did) the driver's side of my 97. Looks pretty darn good I think. A before/after of the rear and an after of the front.
Reply 0
Sep 6, 2009 | 12:49 AM
If you stay on top of them once cleaned they are so much easier to keep clean for the next time! Stay on top of them! I drive mine a lot and just stay on top of it.
Reply 0
Sep 6, 2009 | 09:54 AM
Guys, this is unreal. If I get mine this clean, I don't think I will drive the car anymore... Very impressive though...
Reply 0
Sep 6, 2009 | 11:06 AM
Quote: Guys, this is unreal. If I get mine this clean, I don't think I will drive the car anymore... Very impressive though...
98% of all my aluminum suspension parts are clean and I drive in the rain with no effect on them at all. They still look like I just cleaned them.
Reply 0
Sep 6, 2009 | 11:17 AM
hmmm... really? now it is becoming really tempting to do it myself. Maybe a good winter hybernation project...
Reply 0
Sep 6, 2009 | 11:31 AM
My car is not a daily but I put on between 3500 and 5800 miles per year.
Reply 0
Sep 6, 2009 | 12:34 PM
re milage same here... I sometimes call it a garage queen wanna be...
Reply 0
