How Long do Front Rotors Last (for goodness sake)?
I just bought two new front rotors about six months ago and I think one of them is warped already. I believe I have less then 5/7K miles on them with normal daily driving. I feel vibration on the steering wheel at high speeds when depressing the brake. I haven't tested it with a run out gauge yet, but will this weekend. Any ideas?
Ken
Ken
I doubt you warped your rotors, especially just driving on the street. I haven't warped rotors yet running hard on the track with Hawk HT-10 pads. I've cracked them pretty good, but not warped them. You probably just have some pad transfer you need to burn off of the rotor. A couple of good 60-5 mph stops should help with that.
Here's another thing, did you change the pads when you did the rotors or rotors only? The pads may not be bedded correctly, also when the pads were installed did you use pad dampers between the pads and pistons?
did you change the rotors yourself?
If so, did you well prepare the surface of the hubs before bolting the rotors on them?
last question, do they vibrate since instalation or lately at 6k?
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Purely Porsche Big A. Sunset Porsche parts all the way.
Thanks everyone, I'll report my findings soon.
Ken
Last edited by 993Porsche; 09-01-2009 at 02:34 PM. Reason: Forgot to answer one of the questions.
Lifetime Member
Lifetime Member
My orignaly rotors lasted to 90k miles. Did you happen to spray water into the rotors when they were hot? Like washing your car right after you drove it?
I would check tire pressure first, only a couple of PSI of can cause shimmy. Warped rotors usually only shimmy under breaking, not driving. Next I would reballance the wheels. You may have knocked off a wheel weight when you did the brakes.
Got them from Sunset Porsche. So, I'm pretty sure they're OEM.
Ken
