My top end rebuild begins - First step, dynoed the car today to get the baseline
With more fuel and a Motec, you'll be very happy with the dyno. The sky is the limit when you can play with the ECU.
Which model of motec are you looking at ?
Please take photos of the harness you build, being able to swap back to OBDII will be nice!
+1 on the details, Which Motec? I am interested in your progress, I am looking down the barrel of the same setup.
M600. I don't see any benefit of going with M800.
The plan for the harness is:
1. Get a used BMW E36 ECU for $50 -> tear it apart
2. Use the female 88-pin connector from the BMW ECU and solder the adapter loom onto it.
3. Install Motec plugs on the other end of adapter loom.
-> voila! I have an adapter loom that fits directly to the factory harness and to the Motec.
Fit the ecu socket into the side of a plastic box with a removeable lid, solder your wires onto the back and run the resulting loom through heat shrink & use a cable gland through a hole at the back to the box for strain relief.
-> voila! I have an adapter loom that fits directly to the factory harness and to the Motec.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Nice idea and setup Juha, does the E36 ecu use the same type of plug as our cars? That is awesome, I was thinking of the same setup but was baukling at buying a 993 ecu and tearing it appart......
I am very interested in the outcome, keep the updates coming.....
So your going to use the stock harness with a jumper made from a E36 ECU. NICE!
We used to build all new mil. spec. wire harnesses for the Motec, so I felt it wasn't an option for a street car that had to be tested.
you bet, Here in Canada (alberta) we have no smog or other testing. I have a number of friends that even run Motec on later cars on the street.
I am looking at the M800 as I have a lead on one cheaper than an M600. I think there is great opportunity with Motec and our cars, especially when it comes to tuning for different fuel.
Viggo, I will be in Stockholm on Friday; we will conduct the ice-going tests with the Waxholmsbolaget newbuild m/s Nämdö which we delivered mid December.
Wave at us if you see us on our way to break some ice!
![](http://m3supercar.1g.fi/kuvat/28187/Christer%20Lundin%20-3.jpg/thumb)
I will keep you all posted!
Juha
