What is this part!?
I found this during my fuel cell clamp tightening excursion trying to eliminate the fuel odor. I had to move the expansion tank to do so. Anyway, this morning I was giving the trunk the nose test and I found this rubber grommet type thing lying in the wedge of frame just below the fuel filler tubes on the left side (right side if facing from the front).
What is it and where does it go?
They're the bumper stops that go on the rim of the trunk "frame". They support the trunk lid when it's closed. You should have 2, 1 on each side.
Edit: I was thinking of the 968 ones. See BlackIce's description below.
Well, I did the removal of the expansion tank procedure twice. And this morning I don't think there is any improvement. I just got back from a short stint and it is the same fuel odor. It seems it is emanating from the left side of the fuel cell and the tubing going to the fuel filler cap. I checked and tightened all of the band clamps as far as I dare. None were loose. Could it still be the cap seal? I opened the fill door and stuck my nose in there and I could smell nothing. Go figure.
They sit at the ends of the wall that is right behind the gas tank.
dave
PS - on your trunk smell. Maybe leave your car outside with the lid open for the afternoon. maybe it just needs to air out.
dave
Is there a way to turn off the trunk lamp without pulling the bulb. I didn't want the thing open and put a drain on the battery.
I stand corrected, here's a photo.
Push the trunk latch down as if the trunk were fully closed, that will turn off the lamp. Just remember to re-pop (release the latch) the trunk before you fully close the trunk. Be aware, the lamp is on a delay circuit, it will turn off in a few secs.
I believe I just pulled fuse # 11 which stopped the trunk light and several other interior lights from coming on while the trunk was open. Maybe open the hood to turn on the light and pull fuse #11 and see if the light goes out. If it does it was the one I pulled.
Best of luck.
I had to leave my trunk open for several days to get rid of the smell. During that time period I also took out the carpet and cleaned it and applied baking soda to the interior of the trunk.
Best of luck.
Best of luck.
