993 Forum 1995-1998
Strange noises...
Old Aug 20, 2009 | 07:37 PM
MarkD's Avatar
MarkD
Originally Posted by Shake
Who is the OEM for this compressor? Autozone has a Denso compressor w/ clutch for $350.
EDIT: And also, Pelican has it for $338, not bad!
Denso is OE
Old Aug 21, 2009 | 08:00 PM
Garth S's Avatar
Garth S
Does the AC compressor whine/growl even if the AC is not turned on? .... if so, it is the pulley bearing ( as it turns all the time - only when the AC is turned on does the clutch lock the pulley to the compressor shaft - obviously .
On most of these cars ( on the 928 for sure), the pulley can be removed and a new $10 bearing pressed in.
Old Aug 21, 2009 | 08:03 PM
Garth S's Avatar
Garth S
On most of these cars ( on the 928 for sure), the pulley can be removed and a new $10 bearing pressed in ..... without touching the compressor.
EDIT: Oppps - scratch that, you clearly said " when the AC kicks on ...": had the pulley bearing on the brain, as a 928 was recently by with that prob.
Old Aug 31, 2009 | 12:35 AM
Shake's Avatar
Shake
Did some more investigating, definitely the bearings in the compressor.
Also, just found out, FD Motorsports has the A/C pump for $279, w00t!
Old Aug 31, 2009 | 10:23 AM
manila3's Avatar
manila3
I think if I may ask a similar problem. It's the fan at the engine bay when the engine is off but hot after a run, it's whining and is there a DIY for that?
