Clutch Pedal Hangs up Under Heavy Braking
Need some help here, I posted this same question a while back but no one knew how or what to fix.
Under very heavy braking my clutch pedal will not fully travel back to it's normal position. I've bled the brakes and the clutch and I still have the same issue. What do I need to replace to fix this and why is it happening? My Dad had the same issue on his 95' 993 after he bled the clutch it went away, I'm not that lucky!
thanks,
Dan
thanks,
Dan
No one knows?
this may help ... http://p-car.com/diy/pedal/
I'd guess that the engine/gearbox might be shifting under heavy braking, affecting the clutch. Do you have stock engine/tranny mounts or something else? At this point, most stock engine mounts are long since toast...
Can you explain why the engine moving would effect the clutch pedal? Talk to me like I'm 4 years old!
Who knows what I do when I threshold brake. I usually brake in a straightline, I threshold brake when I brake too late! I guess I didn't mean to say threshold brake, I meant to say when the brakes are at their max.
Thanks!
It is possible that the plastic piece that holds the pre-tensioner screw is broken/cracked and is causing the problem?
Someone recently posted pics...something to look into.
