Replacing the rotors on my 96 993 C4S - any tips?
Hi there,
I ordered a set of front rotors from Sunset Porsche that arrived yesterday. I also have a set of Pagid Oranges that I will be putting on when changing the rotors. This is my first "big" project and I certainly will be looking at p-car and other sites for information/instruction.
Curious if anyone has their own suggestions/tips/experiences.
Nick Shanny
Nick Shanny
Hi there,
Nick Shanny
Nick Shanny
they'll look better than slowly rusting iron.
be careful taking your break-wear sensors off, if you break one, you'll have to buy another or get warning lights.
may as well do a break fluid flush while you're in there.
cheers
Craig
paint the rotor "hats" prior to installation.
cheers
Craig
cheers
Craig
If you don't want to worry about the brake pad sensors you can just clip them at the base of the brake pad and solder the two wires together completing the circuit so no light will come on. Obviously, you will now have to rely on your own inspection of brake wear.
Brake flush for sure...I'll be doing one of those tomorrow on a C4S
Other tips...
- use some penetrating oil on the screws that hold the rotors on as they can get rusty if your car has been exposed to the elements...might be a good idea to have an impact wrench (manual mallet actuated one is fine) just to be safe. You should replace these with new screws ideally with the new rotors.
- since you will be flushing the system...crack the bleeder nipples after attaching a plastic hose to release pressure making it easier to push old pads back to clear the rotor.
Good luck
Lifetime Member
Lifetime Member
Buy yourself an impact screw driver from Sears. The screws sometimes can get rusted on the rotor and a standard screw driver will likely strip them.
Depending if you want to transfer the dome shaped anti squeal shim over or not, you may need to have some disc brake quiet glue to glue the shims onto the new pads.
I thought you only had to paint the zimmerman brand rotor hats as the genuine porsche one's came painted...I THINK this is how you tell if you have a genuine porsche rotor or OEM zimmerman.
Other tips...
Good luck
Other tips...
Good luck
Adam (and all),
I ran into an interesting factor when ordering rotors for someone recently. Apparently they have been doing this for a year of so.
Zimmerman has heard our cries regarding corrosion. Check out the link below.
And at considerably less $$ I think it is worth reconsidering these. I know I will be on my cars.
http://www.otto-zimmermann.de/index.php5?Itemid=136
When I replaced my rotors, I ordered all the plastic clips and holders for the sensors from Sunset. You are bound to break one or two the first time they come off. Real cheap too.
Before anyone thinks Zimmerman are a lot cheaper, check OEM prices from Sunset (made by Zimmerman, btw).
That Philips head screw that holds them on - put anti-seize on it when you reinstall.
Nick,
If you are tracking the car, maybe those Pagid Oranges are necessary, but if you like nice & quiet, no-squeal.....the consensus seems to be that the OEM pads & anti-squeal spiders (on the back of the pads) are THE way to go. Robin mentioned transferring the spiders over, but I just got new ones...don't remember how much, but it wasn't that expensive (Maybe it was that after the 4 new rotors for the C4S, the rest of the stuff seemed cheap...). And I put on new bolts as suggested...for the couple of dollars, worth the piece of mind. I did reuse the sensors.
I went with OEM everything and have had NO squeal issues since.
Yes we will!
<----That one!
<----Is that a hint that I need to remember to bring beer???
<----That one!
Okay, enough de-railing this thread...back to your regularly scheduled programming....
King of Cool
My advice: buy OEM.
+1 on Robin's impact screw driver, I have the kind that you hit with a hammer.
I had been told that there are two types of Zimmermans, the OEM and the aftermarket version that are cheaper (in the same size). The ones I recently bought from my local dealer came in a red lettered Porsche box, but were the OEM Zimmerman's.
I heard that oem rotor holes were cast, aftermarket Zimmerman's were drilled...or do I have that bakcwards?
Hi there,
Thanks to everyone who responded. I will be ordering the extra parts just to be safe. No reason to screw around with brakes.
Thanks again
Nick
Thanks again
Nick
