Dear God - Not another Oil Thread!
Can any of the oil gurus please comment on ZDDP Plus?
www.zddplus.com
Is anyone here using it?
Thanks and best wishes
www.zddplus.com
Super Moderator
Needs More Cowbell
Needs More Cowbell
Similar products have been discussed in various forums, 996TT IIRC.
GM engine oil break in additive was often used for this purpose and discussed but AFAIK, it is no longer available?
Noodle Jr.
For some reason people will go on for days and want to kill babies in the oil threads but won't even respond to this topic???? I too would like to know.
RL Technical Advisor
JMHO,.....................
ZDDP additives are OK for engine break-in & racing, although there are now specific break-in and racing oils formulated for those express purposes. I used GM's EOS since 1967 to break in all my race engines,....
Today, I would not use nor recommend a ZDDP-enhancing additive for general use due for the requirement for a balanced detergent package that combats piston & ring deposits caused by high levels of ZDDP.
Good oils are complete chemical packages that balance engine wear, friction, and detergents to keep the engine functioning properly and I'd strongly recommend using a good oil instead of trying to doctor up a product with unintended consequences.
EDIT: Oops, too slow. ^^
From what I gather it's best to just use an oil that has proper P/Zn concentrations to begin with, instead of using an add-in product.
Here's a thread on the add-in products and such:
http://forums.pelicanparts.com/showthread.php?t=459454
From the mega oil thread on Pelican:
http://forums.pelicanparts.com/showthread.php?t=367300
Bonus link:
http://www.lnengineering.com/oil.html
... the Cliff notes answer is: SWEPCO 15W-40 or Brad Penn 20W-50. Ther are other oils out ther as well. If they are NOT API SL, SM or CJ4 rated, chances are they may be ok.
Howdy,
Instead of posting in the wee hours of the morning, you should have been making your way over to Cars and Coffee. We had a good time and there were about 8 993s there today.
My last two oil changes have been w/ B Penn. What Steve W says makes a world of good sense. Sometimes its hard to keep things simple when you're stupid.
