FD Motorsports - Short Shift Kit (SSK)
Just finished the install of the FDM - SSK. The kit includes a modified RS shifter, an RS fork, the infamous "Golden Rod" and a new guide tube (front shift rod). In addition to shortening the shift throw, The kit eliminates 3 sloppy components in the oem shifting linkage. 2 - ball and socket joints (front and rear connection on the guide tube) and 1- big sloppy rubber bushing (on the gear shift rod). All the parts are either new or modified by FDM are very well done with good fit and finish.
The installation is easy and can be completed in a couple of hours. I would rate it at about a 4 or 5 on a scale of 1-10. I did the install w/o the DIY. I made the mistake of installing the shifter backwards. I used the Porsche PET for the reassembly of parts. Not a good a idea and should not be used for assembly.![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
I think the PET shows it reversed for illustration. This put the shifter waaaay forward and a little to the right. After discussions with the NoCAL boys we figured out what went wrong. There are rumors that others (Mr. Cactus) made the same mistake...so I don't feel so bad![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Since you rotate the oem shift tube bearing sleeve (2 required) 180 degrees, the shifter sits higher than oem. I cut about 3/4" of the top of the new RS shifter which lowers the **** to the right placement. Thanks Darin.![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
The FDM SSK has a shorter throw and is crisper and more precise than the oem. This is a major improvement to the oem setup which IMHO sucked.
PS. These guys are awesome to work with.![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
Bob-
Bob-
CraigDK (12-08-2021)
Noodle Jr.
HA! Did the same thing off of the PET picture so I feel your pain. Two things: I can assemble/disassemble a 993 shift linkage with my eyes closed and the second is Mark and Darin deliver top notch parts/service/and beer(or so I hear on the last one)!
PS Armorer
I just finished installing the SSK and Golden Rod. What a nice improvement! Much more direct/precise feeling and shorter throws (obviously). I left the RS rod at it's original height, as this seems to fit me better than the non-RS set-up anyway. And it's more pukka ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
This is a two-beer install. Took me two hours by myself to add the SSK to the Golden Rod install I did a couple of weeks ago, and I wasn't in any hurry. It is not particularly difficult. The toughest part for me of the whole project was aligning the hole in the Golden Rod with the transmission shaft. The tolerances are tight, as they should be. A little emery paper solved it pretty quick. The SSK part was a snap.
Mark, your instructions are great-thanks for finishing them up so quickly.
For anyone on the fence about this (and wondering who are these guys?), I have to say this is a great upgrade and Mark and Darin are an absolute pleasure to deal with. Proceed with confidence.
I received one of the prototype kits and have been running the SSK for three weeks now, including a weekend at the track (see my new avitar)... The difference in shift quality is truly AMAZING! Everything is more direct... and the RS shift height is perfect! There is a bit more vibration transmitted thru the shifter, but it isn't objectionable at all...
I am extremely satisfied and highly recommend this modification to anyone who wants a better shift feel for their 933!
Deadeye,
I'm sure they will chime in, but they actually use a factory RS shifter, modified to permit attachment of their spherical rod ends... The kit addresses both ends of the linkage and removes all slop in the system. Trust me, you will love it!
On the AWD cars it is not a bolt in kit. The front mount point is affixed to the torque tube. You also need to create some room on the center tunnel cover for the lower position of the RS lever (since the shift box is actually the torque tube, there are no bughings to reconfigure, see more in the install guide here: http://www.fdmotorsports.net/SSK%20DIY.pdf The bushings you see that need to be flipped are not there on a C4).
Michael nailed it... the most cost effective route are the Porsche RS parts and modifying the lever.
Thanks for the nice comments Bob, Jason and Michael. We are doing our best and having a pretty good time doing this stuff!
Here's another postive vote for the FDM - SSK/Golden Rod upgrade. I had my car in the shop today for some routine stuff and had them install the kit for me. Hey, they're better than me, so why not?
Bottom line: GREAT! Love it. Shifts are smove and precise. Throws aren't as short as I expected but they are indeed shorter and the overall improvement in operational feel is amazing. This is what the P-Car OEM shifter should have been but wasn't.
I'm thrilled and recommend this upgrade to everybody who hasn't yet done so.
Two of my biggest gripes with this car are the OE suspension and the shift linkage... changing both make a world of difference
I'm all set, then. The PO swapped the OEM suspension for some major improvements.
The only thing left for me decide is the wing and splitter question: Should I or shouldn't I? If so, which?
Oh, I almost forgot the basket handle. I haven't decided on that either. For now, I'm going to drive and enjoy it as is.
FOLLOW-UP: Two plus months after the install, I went into the garage, started my 993 and tried to put it into reverse. Nada. No nothing. The shift lever was swinging freely without being connected to anything. Bummer.
As bad as that is, it's amazing it happened in the safety and convenience of my garage, rather than on a twisty somewhere at 90 mph or at a stop sign 100 miles from home. About that I'm thrilled.
I had my mechanic install it for me the last time I had the car serviced. I'm taking it back to him because he'll stand behind his work if it's something they did wrong or not well. At this point I'm assuming it was faulty installation, rather than anything wrong with the FD Motorsport SSK or RS Rod.
Duckman! That stinks... please let us know what you find.
If you feel nothing (very loose, no resistance at all) it is likely the little e-clip came off and the shift rod dropped off of the shift lever. That clip has to be in it's groove and if it is not seated completely... well, this happens.
Very fortunate to have this happen in your garage.
