993 Forum 1995-1998
Broken Door Pockets
Old May 19, 2009 | 09:49 PM
IamSMC's Avatar
IamSMC
Anything here?
http://www.wclco.com/Threaded_Fasten...Assemblies.php
Old May 19, 2009 | 10:05 PM
Bola964's Avatar
Bola964
Thank you guys!
They are all good ideas, and I'll start with the simplest one and work my way up if necessary.
In any way, you guys just helped me save lots of $$$......
Cheers,
Old May 20, 2009 | 03:16 AM
Mike J's Avatar
Mike J
I followed along some of the suggestions, I used a piece of thin aluminum sheet metal, bonded that to the back of the broken piece with JB Weld (cut to fit), drilled a new hole, sprayed it all black, and viola...been working like a charm for the past 5 years.
Cheers,
Mike
Old May 20, 2009 | 04:42 AM
Amfab's Avatar
Amfab
Originally Posted by Cincy_Ron
Ed, I've always wanted to ask you about your avatar. I'm assuming that's your son. And you're at some type of barbecue. And the hot blond over his left shoulder, with the look on his face like "oh yeah, she's hot". I'm assuming there's a story behind all that. ;-)
+1
along with the mixer in the flight case and how it fits in to the story
Old Jun 1, 2009 | 09:10 PM
rol607's Avatar
rol607
Found them.
Here's dry fitting the plexi to fit in the indent, and the after shot with it painted and epoxied in place. It's been holding up well. According to the date on the pictures I did this in August of last year.
Ron,
Did my passenger door yesterday as instructed by you. Turned out great. Hope it holds!
Old Jun 1, 2009 | 09:28 PM
Arena993's Avatar
Arena993
I did mine with the bigger washer. We wil see if it holds up. Is there a 993 door pocket that isn't broken there?
Mike
Old Jun 1, 2009 | 09:40 PM
mongrelcat's Avatar
mongrelcat
Mike
I thought I was the only one with this problem, LOL. Every picture I see of a car here or for sale has seemingly nice, perfectly square pockets.
I mentioned the issue with my car to a local restoration shop and they were like "Oh, yeah, they all do that. We just tack 'em up with some aluminum stock and all is well again."
Old Jun 1, 2009 | 10:34 PM
Dudley's Avatar
Dudley
I fabricated a steel saddle that I cemented to the broken door pocket. I painted and drilled the steel piece and it has held up for the past few years.
7 Porsche Models That Have Aged Like Fine Wine
Old Jun 1, 2009 | 10:40 PM
Arena993's Avatar
Arena993
They have all been fixed. It's just an illusion they have all been broken at one time or another.
Mike
Old Jun 1, 2009 | 11:26 PM
rol607's Avatar
rol607
Dave,
Would love to see a picture of your setup.
Old Jun 1, 2009 | 11:41 PM
mstolo's Avatar
mstolo
I used a product called Plast-aid. Its a pretty cool product with a lot of uses. It basically allows you to mold this soft material into any shape you want, you let it harden and then drill the hole. You can add black paint during the mixing process and get black plastic. It hardened extremely fast and extremely hard.
Here is the website.
http://www.plast-aid.com/
I do like the idea of using plexiglass or solid piece of plastic, as its probably cheaper and a cleaner fix than using Plast-aid. But, i'm sure there are some other applications for this product that people might be interested in.
Old Jun 2, 2009 | 12:18 AM
TheOtherEric's Avatar
TheOtherEric
Jb Weld worked for me.
Old Jun 2, 2009 | 07:21 AM
Dudley's Avatar
Dudley
Here is my repair.
Old Jun 2, 2009 | 01:41 PM
Paul902's Avatar
Paul902
Good discussion, guys. I need this on my driver's side pocket.
ps...I'm also curious to hear about Ed's avatar.
Old Jun 2, 2009 | 11:46 PM
JimPA's Avatar
JimPA
My driver's side is broken but not as bad as the first car's photos show. I bought a small L-shaped flat steel bracket. I was going to paint it black and install with the lower part of the L facing forward to support that whole area. The JB weld and flat black aluminum or plexiglass fix sounds better.
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
