Daylight Running Lights
Super Moderator
Needs More Cowbell
Needs More Cowbell
On the 964 there is a relay that can be installed to turn the fogs into daytime running lights.
With the headlights turned off the fog lights are always on. When the headlights are turned on the fogs work as normal; when the switch is pulled and the high beams are off, otherwise they go out.
http://www.schatzmotorsport.com/orde...cat=255&page=2
Mine didn't have the wiring to the fuse block. The independent shop (Don Jackson) installed the components so it looked like a factory install. They have no myth to perpetuate and just looked at the wiring diagrams.
