Metal Valve stems ?
Metal Valve stems ?
Do I need to have metal valve stems on the 996 TT Hollow spoke wheels? I purchased a set of refurbished wheels without the valve stems in them. Checking if I can use regular rubber stems.
Jason
96 C4S
Jason
96 C4S
Hijack
Roche, do you have a side view pic of your car with those wheels? your avatar doesn't quite show enough of the wheels. What color are those wheels?
/Hijack
/Hijack
sorry for the hijack........
the wheels were stripped and powdercoated an audi dark metallic gray and then finished with a matte clear coat. they look great in the sun, the metallic gets picked up but the matte clear keeps them from shining too much.
a couple pics:
a couple pics:
I've also had the rubber stems fail and switched to metal ones.
There are some pretty trick ones available with wireless pressure sensors out there if you're so inclined....
I was actually browsing Suncoasts parts specials the other day and they show the different types of valve stems. I've got a set of hollow spoke turbo twist wheels in the garage and didn't realize they take a special valve stem. Looks like you need set "C".
http://e-partssales.com/Merchant2/me...Code=POTE993WH
