993 Forum 1995-1998
Brad Penn oil
Old 04-22-2009, 09:47 AM
ironimages
ironimages's Avatar
Default Brad Penn oil
Ok, not to start another "oil war" here on the forums... But is anyone using Brad Penn grade 1 10w40 or SWEPCO 306 10w40 in their 993?
Old 04-22-2009, 10:53 AM
Paddy
Paddy's Avatar
I used Swepco 20w50 in my 993 and have been happy. Plus, I can pick it up locally.
Old 04-22-2009, 11:17 AM
b5audia4
b5audia4's Avatar
I think I will try BP 10W40 for the Fall oil change before putting it away for winter.
Old 04-22-2009, 02:20 PM
ironimages
ironimages's Avatar
Ok, any other Brad Penn users here? Chime in please!
Old 04-22-2009, 02:23 PM
axl911
axl911's Avatar
I use it and is happy with it. Cheaper than Mobil 1 but with the necessary ZDDP.
Old 04-22-2009, 02:37 PM
993Maineiac
993Maineiac's Avatar
I have been using it since the last change and am about to order another case. Car's been running nice and cool-no problems.
Old 04-22-2009, 02:41 PM
dcdude
dcdude's Avatar
I'm running BP 20W50. It's fine.
I think someone here suspected a slightly higher operating temps, but that may have been condition-dependant. I have seen zero change in operating temp from Mobil 1.
Old 04-22-2009, 02:50 PM
ironimages
ironimages's Avatar
So, Brad Penn 1. should I get 10w40 or 20w50? for a 96 993? I will be using this car in the North East.
Old 04-22-2009, 02:53 PM
993Maineiac
Just make sure it is the race oil.
Old 04-22-2009, 03:02 PM
jaholmes
jaholmes's Avatar
I'm using the the 20-50 Racing oil. No issues here. This is my 1st change though.
I think there is the other version that is not race oil but I forget what weight it is. The decision is do you track your car or not.
I got my oil from LN Engineering.
Old 04-22-2009, 03:24 PM
axl911
axl911's Avatar
10w40 or 20w50 depends on what is the ambient temperature you normally drive. The manual specifies what oil to use based on ambient temp.
Old 04-22-2009, 03:27 PM
ironimages
ironimages's Avatar
No, I have no plans to track the car, so 10w40 grade 1 racing oil will be good?
Old 04-22-2009, 03:29 PM
ironimages
ironimages's Avatar
Western Pa, so temps 30-90 mostly around 70-80's for summer
Old 04-22-2009, 03:42 PM
fullbooker
fullbooker's Avatar
I "changed" to Brad Penn Racing 20-50 at last oil change. I can not tell any difference from the Mobil 1 I used before.
Phil
Old 04-22-2009, 03:57 PM
flatsixforme
flatsixforme's Avatar
I am on my second oil change with BP and I mixed the 10w30 and 20w50 to get 15w40. Bought one case of each which gave me enough for 2 oil changes and oil in between to add.
I like it on paper with the added anti-wear additives and it is very reasonably priced. In a perfect world it would be a full synthetic (it is 10% synthetic). If cost was no option I would proably go with redline as it has the anti-wear additives and is a full syn...however, almost twice the cost. I AX/DE my car quite a bit so I change my oil more than once a year. If I left it in for a whole year I would proably want an oil analysis to see if it is holding up.
I plan on continuing to use it. Hope that helps.
Quick Reply: Brad Penn oil
